Question about Janome 6260QC Computerized Sewing Machine
Jamming or timing at bobbin
My janonome quilters started jamming at the bobbin. Have re-thread, re-bobbin, changed the needle, cleaned out dust. The bobbin shuttle seems loose
    New Friend:
  • 184 Answers
The bobbin case should be loose enough to wiggle a little. Take it out and look for needle strikes or damage on the edges, if it is damaged you can try to smooth it up with fine file as a temporary fix but purchase a new one soon as possible. The other two factors to look at is the upper thread take up lever, make sure the thread is in it and then check the upper tension by pulling thread thru the needle. When the presser foot is in the raised position, the thread should pull thru the needle easily, when the foot is lowered onto the fabric, the thread should be hard to pull. If it is still easy with the foot down then the thread did not go into the tension discs properly or the upper thread tension dial is set at too low a number. It should be on a 3-4 or 5kif I remember correctly.
Posted on Jun 03, 2010
I have Babylock Quilters Choice. How do I set up to quilt? It won't pick up bobbin thread.
Be sure to install a brand new needle. Bent/dull/damaged needles sometimes will not pick up the bobbin thread.
If it still will not pick up the bobbin thread, there may be a timing issue (the needle does not arrive at the bobbin at the correct time to intercept the bobbin thread). Take it for service.
Sep 23, 2016 | Sewing Machines
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Pfaff 2024 bobbin case basket is jammed-even after clean & oil
the jam that happened may have caused the machine to jump time & it would have to be serviced
May 16, 2012 | Sewing Machines
Get thread from bobbin upto sew
try rethreading the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
change the needle--flat side to the back of the machine
clean under the needle plate & in the bobbin area for loose threads
& lint
make sure the bobbin is not damaged like warped or bent
May 01, 2012 | Elna Quilter's Dream 6003Q
Mega Quilter tension inconsistent
change the needle--needle must be correct one for fabric sewn
adjust the top tension--make sure there is no lint or loose threads
in the top tension dial
also clean under the needle plate & in the bobbin area for lint or loose threads
make sure the bobbin is inserted correctly--some bobbins only go one way
Apr 18, 2012 | Sewing Machines
The bottom thread bunches up
try changing to needle
check the top thread tension--try 3 or 4
clean under the needle plate for lint or loose threads also in bobbin area
make sure bobbin is in correctly
Aug 04, 2011 | Necchi 3620 Quilter Mechanical Sewing...
Husqvarna mega quilter is bunching bobbin thread when quilting. Top thread looks fine. I have tried adjusting tension. what should I look for?
try a new needle
clean these areas,,under needle plate,,,bobbin area
check to make sure the thread has not come off the thread take up lever
Aug 02, 2011 | Husqvarna Sewing Machines
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
I was sewing a straight seam and all of a sudden the thread wouldn't pick up the bobbin thread anymore. Now I can't sew and have much to sew for a wedding in 5 days. Can I fix this myself? When I turn the...
If you can hear a click then I'd say the needle is touching some part of the hook mechanics which could mean timing is out. However, it is possible that the bobbin case has just moved a little so as first trouble shooting steps, I'd suggest the following:
clean out the bobbin holder area as per manual (ie. remove the needle plate, bobbin, sewing foot and needle, take out the bobbin holder, clean the race area out, then put bobbin holder back in as per your manual, there is usually a stopper and knob or two red marks to line up. This is held by a magnet so it is possible to knock it out of place during a jam up.
Replace needle plate, bobbin, sewing foot and put in a new sharp needle, flat shank to the back and make sure it is fully up into the holder, thread up and very slowly using the needle up and down button, test sew a couple of stitches again.
If no stitch formation or you can definitely hear/see something touching then I'd say timing is out and no, its not something fixed yourself; best left to a trained technician.
Apr 11, 2011 | Elna Quilter's Dream 6003Q
Janome 6260QC Computerized Sewing Machine Logo
197 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
