Question about 2wire (1000-100052-000) 802.11g/b Wireless Adapter
I have a 2wire wireless adapter card for my laptop computer i can not configure it because the numbers that came with the product are too long and it wont allow me to put them in
    Scholar:
  • 130 Answers
The numbers that you need to connect to your wireless network are determined by your router.
If you have security on your router, you need to use the same type of security on the adapter card. You will also need to know they key from the router.
If you don't know your router's key, you will need to login to the router to determine the key. You normally just need to login with your browser to the router. Because I don't know which router you have, I can't tell you the address of your router.
However, you can get the address of your router by going to a computer that uses the router. Following this series of commands
  • start
  • run
  • cmd (type in)
  • in the black window, type "ipconfig"
  • note the "Gateway" address
On this same machine go to your browser and type, http://192.168.X.X where X.X are the last parts of the Gateway address. When you go to the router. It may ask for a password. Common users/passwords are: admin/admin , admin / (just enter) , admin / password.
You can then look on the wireless settings to find your network key.
Hope that helps. Good luck.
Posted on May 27, 2010
I use 2Wire router and usb adapter. I switched
you dont need to install the driver for the 2wire, you just need to configure the computer to look for the 2wire, if unable to locate the 2wire from your computer, there is a problem on your 2wire it self
Jun 13, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
How can i configure WPA security on my 2wire modem
To connect to your wireless router, it needs the router’s wireless settings configured and also needs the wireless cards in all the laptops and or computers to be configured with the router’s wireless settings. Then the laptops and desktop computers can communicate with your wireless router.
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Nov 22, 2009 | 2wire Computers & Internet
2WIRE Router, Belkin Card, and 10 vs. 13/26 digit encryption key
I would give you two options
1. to change ur wireless key to fit to this card
2. u can still let windows configure wireless for this card as well
However would like to have a clearer report about the problem
Jul 05, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I cant connect my 2 wire
Try going to the 2wire website ...
http://support.2wire.com/index.php?page=download
Not sure from your post if your using the adapter or their gateway.
Apr 18, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I need help installing my 2wire wireless adapter card.
I used this one:
Introduction
This document describes the procedure to install driver for the 2Wire Wireless USB Adapter under Microsoft Windows, and to run a wireless configuration program to configure your 2Wire Wireless USB Adapter to work with a 2Wire HomePortal or OfficePortal wireless gateway. These drivers work under Microsoft Windows 98SE, ME, 2000, and XP.
STEP 1 - Driver Installation
1. Make sure your 2Wire Wireless USB Adapter has not been connected to your computer USB port.
2. Double-click on the file to run WinZip Self-Extractor. The driver installation files will be placed in your hard disk in the C:\TWWUSB_TEMP directory
3. Connect your 2Wire Wireless USB Adapter to an available USB port in your computer. Windows Found New Hardware Wizard will startup.
4. Select the option to search for driver in specific location. Specify C:\TWWGUSB_TEMP as the location of driver.
5. Follow on-screen instruction to finish driver installation.
STEP 2 - Wireless Configuration
1. Run the program WirelessCfg.exe in the directory C:\TWWGUSB_TEMP. You can do so by clicking on the Windows Start button and select Run. The Windows Start button is typically at the lower left corner of the screen. Type in C:\TWWGUSB_TEMP\WirelessCfg.exe to launch the program.
2. Follow on-screen instruction to configure your wireless setting. Enter the serial number and encryption key as they are printed on the bottom of your 2Wire wireless gateway.
Sep 28, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
How
Hi
enter the serial number and encryptian code as directed to configure my 2wire wireless PCI Adapter and it does not recognize it.
You can find all the drivers and the manual for your Wireless Adapter here: http://www.2wire.com/?p=331
May 30, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Computer recognizes the card, but configuration utility does not?
Hi
Install the compactable drivers,You can find all the drivers and the manual for your Wireless Adapter here: http://www.2wire.com/?p=331
May 28, 2008 | 2wire (1000-000005-002) 802.11g/b Wireless...
Connecting 2wire router with desktop pc and laptop
hi! try to check the settings on your 2wire modem, you can do this by going to gateway.2wire.net, run the system setup wizard, when you get to the ppp authentication page, check the username & password on it, it should be the one that you setup for your ISP account. as for the wireless on the desktop, it depends on the brand of the wireless adapter, be sure you have installed the drivers for this adapter. you may need to go to the client utility manager or the wireless adapter shortcut/icon on your computer screen then configure it to "see" the 2wire network. make sure wireless encryption is turned on in the 2wire modem's MDC, you can do this by going to homeportal/management, or go to gateway.2wire.net/mdc.
Apr 11, 2008 | 2wire (1000-400108-001) Router
2wire 802.11g/b Wireless
what's your ISP name? for list of activation keys or keycodes go to:
http://www.2wire.com/?p=268
as for the serial nos. well every product has its own unique serial no. and you can't change that; it's every product's unique identity.
Mar 21, 2008 | 2wire (1000-100052-000) 802.11g/b Wireless...
Configuration
You should either install the driver software that came with the card or insert into your PCMCIA slot on the side of your laptop of which windows will then identify as new hardware, then install the driver.
Mar 16, 2007 | 2wire (1000-000005-002) 802.11g/b Wireless...
2wire (1000-100052-000) 802.11g/b Wireless Adapter Logo
101 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
