Question about Philips Universal PH301S Remote Control
Cannot get the universal remote to switch from dolby to stereo
I've got a Digital Stream Dolby digital DTV box, I need to know what codes will work to program It into my GE universal remote control.
Code, if applicable, will be in your GE remote. Use code search to find the applicable code. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store possible codes.
Aug 16, 2016 | GE Televison & Video
CODES FOR UNIVERSAL REMOTE
Check the database of the maker of your remote.
Mar 15, 2015 | Sony BRAVIA KDL-40W600B 40" 1080p LED-LCD...
I have receiver THIS MORNING PLAY I COMFUSE WHY THE BOTTOM OF DSP, DSP LOGIC, BYPASS,DOLBY PRO LOGIC,DOLBY 3 STEREO BECOME ON INTERCHANGE. LET SAY WHEN I PRESS THE BOTTOM DSP LOGIC ON THE SCREEN IT SH
Get a better translator. Sounds life bad solder job on board. Check buttons wire connections and where they hook up. If it'd the display which I Dont think it is try checking those wires. Good luck.
Jan 04, 2015 | Audio Players & Recorders
My techwood won't play sound and the colour is completely wrong. How do I fix this?!
please see the chart troubleshooting. and fix it. God bless you
No sound
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Oct 14, 2013 | Gemini 1 Device Universal Television...
Ge universal remote codes for a Dolby digital converter box
I have a Dolby Digital Analog TV converter box, however i cannot successfully activate it.
Because it was given to me as a gift, yet there was a V Chip Password that was set. I cannot retrieve that password.
What are my options? Thank you
Jul 24, 2012 | Televison & Video
How do I get the C5 Subwoofer to activate?
Hello
If subwoofer is inactive now, the sound preference settings you set now is wrong.
Before using the remote control for the following
operation
* Set the remote control mode selector to AUDIO
** There are exceptions in the operation mentioned
above. In such a case, follow each instruction
Dolby Pro Logic II*1
# Dolby Pro Logic II has a newly developed multichannel playback
format to decode all 2 channel sources - stereo source and Dolby
Surround encoded source - into a 5.1 channel.
Dolby Pro Logic II has two modes - Movie mode and Music
mode
# Pro Logic II Movie (MOVIE)
Suitable for reproduction of Dolby Surround encoded sources
# Pro Logic II Music (MUSIC)
Suitable for reproduction of any 2 channel stereo music sources
# Dolby Digital*1
Used to reproduce multichannel soundtracks of the software
encoded with Dolby Digital
# DTS Digital Surround*2
encoded with DTS Digital Surround. DTS Digital Surround (DTS) is another discrete multichannel
digital audio format available on CD and DVD software
Jun 19, 2011 | JVC TH-C5 System
Remote is no longer working
i need a universal remote that can work for a jwin dvd player
Feb 03, 2008 | Jwin JD-VD502 DVD Player
Televison & Video Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
