Question about Panasonic TH-42PX25U/P 42 in. Plasma HDTV
Panasonic plasma will not scroll through inputs but stays on pc in put only.
  • 4,889 Answers
I have seen this happen in several panasonic plasmas due to logic control board failure. However lets try a reset. Turn off the tv, unplug from the power supply and wait for 2 min. Then plug it back in press and hold the power button for ten seconds and then fire up the tv. See if the issue is resolved and let me know.
Sai.
Posted on May 27, 2010
  • 4 more comments
  • Eric Bartel May 27, 2010
    Thanks for your reply. I tried this and it does not change anything. I also took it to a repair shop where they told me the problem was the PF board and they wanted $500.00 to fix it. I said, no thanks and ordered the part and installed it myself. I think this fixed one of multiple problems but this is what got me to where I am today... I can use the TV in PC input mode and it acts like it switches inputs but it doesn't. I would like to know which board I need to replace next. Can you help me figure that out?
  • eagle338
    eagle338 May 27, 2010
    It is the logic control board that you have to replace. Costs about 150-200 bucks.You can try getting the part from http://parts.pioneerelectronics.com/cust...
    so that you can be sure that you get the original replacement and a 1yr warranty on the part that you have replaced.
    Are you sure that is the correct URL? That is for pioneer and not panasonic.
  • eagle338
    Thank you. I will try to replace it and get back to you.
  • eagle338
    Surething. Good luck!
My th-42px80u Panasonic plasma tv has no picture or sound red light stays on
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 17, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Optical port problems
a suggestion, take it back and tell them when you opened the box it was this way--a whole pc board is likely to have to be replaced that has the connection on it.
Dec 23, 2012 | Panasonic VIERA TC-P50ST50 50-Inch 1080p...
Panasonic TH-C42HD18 42 In. Plasma TV inputs not working
yes. you find the main board for you panasonic plasma tv from shopjimmy.com.. good luck!
Sep 03, 2012 | Panasonic TH-C42HD18 42 in. Plasma TV
I have a 2010 model Panasonic Vierra Plasma, 55" screen, and we recently noticed a narrow, horizontal, slightly dark shaded band that is continuously scrolling from the bottom to the top of the...
You might try isolating the source by disconnecting the cable (or satellite receiver) and try it with another input device such as a DVR, VCR or other video source. This banding was not uncommon on analog sets but very seldom seen on our current digital sets. But, it could be embedded 'noise' in the signal coming in from outside the set.
Feb 16, 2011 | Panasonic TC-P54V10 54 in. HDTV Plasma TV
Pc connected to th42phd7 but no picture, input button doesn't
are you on the right input. To use this set as a monitor you do have to change some settings in the options part of you tv. Also you need to make sure the set is on the right resolution for the PC. check you video options on the PC, and make sure they are the same on the TV set. Also you will not get sound from this type of cable..good luck
May 04, 2010 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Wii hook up with my Panasonic tv
Simply plug the yellow, white and red plugs into the INPUT 3 ports on the front bottom of your TV. Use your TV/Video button (either on the remote or next to the INPUT3 ports) and select scroll to the Video3 option. Ensure that the 3 plugs are firmly pushed into the ports. My initial problem occurred because I thought they were pushed in all the way, but they weren't. You do not need to have your tv on any specific channel for this to work.
Jan 02, 2010 | Panasonic Viera TH-42PX80U Plasma TV
How to connect Panasonic Plasma tv with satelite hookup to playstation 2
U can't hook the satelite signal to the PLaystation 2.The satelite hook up to the main in the Antana input.The playstation 2 must use the RCA cable came with the Playstation 2 hook up in any Audio,Video in put in the the tv.Tune in what input u hook up like 1,2,3,extra..use ur Playstation 2.
Aug 25, 2009 | Panasonic Viera TH-50PX80U Plasma TV
How to conect a pc to a panasonic plasma th50px75u?
Panasonic didn't make it a simple matter to connect a computer to this TV since they didn't include a VGA input connector. You can still do it, but it will require some adapters or changes to your PC.
If you're using a laptop, you have two options. If the laptop offers an s-video output, you can use a suitable cable from there to one of the set's s-video inputs. If there's no s-video output, the other option is to purchase a VGA-to-component breakout cable, available at a number of online vendors (search with Google). This cable has the VGA connector to the computer on one end, and 3 RCA plugs at the other end. You would use this cable into one of the set's component video inputs.
With a desktop PC, you can still use one of those two options. In addition, there may be a DVI video output connector available as well. This is not common on computers with integrated video, but is frequently found on many newer expansion video cards. If your computer has this connector (or you install a new video card with one), you can use a DVI-to-HDMI adapter and connect an HDMI cable to one of the set's HDMI inputs. Many video cards with DVI outputs include one of these adapters already.
So while it's not going to be simple, it's certainly possible to connect your PC to this TV.
Feb 03, 2009 | Panasonic TH-50PX75U Plasma HDTV
Panasonic TH-42PX25U/P 42 in. Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
