Does the acer aspire notebook record sound? It
Does the acer aspire notebook record sound? It has a mic. which I have used with a headset.
    Guru:
  • 509 Answers
If it has a sound recorder it would be in the start menu under...programs...Accessories...Entertainment.
Posted on May 27, 2010
Testimonial: "thanks again, twice in the one day, I where to go now when I can't work it out. Regards Leanda"
When i talk on skype so no body hear my voice
Try your Sound settings, Recording/Playback/Mic device settings, you may need to setup for headset.
Feb 20, 2013 | Acer Aspire 3680 Laptop
Hello fixya. I just reinstalled windows 7 for my acer aspire 5943G but for some reason i cant get the mic in the computer nor the mic in my headset to work, i dont know if its because i need a driver,...
Check the device manager to see if a microphone is installed. If it is, it may not be installed correctly due to a missing driver or wrong driver. If you find a mic installed, right click and get the properties. Find the tab that says Update driver and allow the laptop to connect to the internet to find the right driver. If no microphone is detected, you can manually install the microphone through the Control Panel under Devices/ Add Hardware. From there, you will select microphone and be given the option to either install it with a disk or by selecting the manufacturer/model.
Jul 20, 2011 | Acer Aspire One PC Notebook
I connected several external mics but still can't get good audio on the test I configured my 5515 to the type of mic i'm using, but very weak. I adjusted the amp to max but mostly get background noise. ...
if this happens to both internal and external mic and to a headset, chances are, its an issue with your audio controller. reinstall/update the audio driver and try to use different recording programs
Dec 04, 2010 | Acer Aspire 5050-3242 Notebook
Micro not working...
I honestly think that we dont weven have a mic, I have the same Nettop and i see the little mic simbol but when i attempt to use it, it does not work. I always have to use my headset to record sound on it.
All mics on aspire ones are defective, heck, there are some people that say even their externa; mics dont work
Aug 01, 2009 | Acer Computer AOA150 Notebook
Acer aspire 5735 mic problem
Go to control panel and sound devices and unmute the mic under record options. To avoid feed back use headphones or mute the mic in the play back option. Audacity is a good open source application to use to record on your PC.
Jul 25, 2009 | Acer Aspire 5735 Notebook
Acer Aspire internal mic won't work.
You need to check the record settings and make sure the mic is not muted or turned down to low. Click START, CONTROL PANEL, then SOUND icon. Click the AUDIO tab up top. Make sure that your sound card is selected in the drop down menu under Sound Recording. Now click VOLUME tab. A new window will open up. Click OPTIONS then PROPERTIES. Make sure you have a check by the MIC and click OK. In the Recording Control window, turn the level up for Microphone and make sure it is not muted. Let me know what happens.
May 02, 2009 | Acer Aspire One PC Notebook
Internal mic does not work
Be sure to find up-to-date drivers for your mic. What kind is it? That is most likely your problem. Either that, or you installed something that is conflicting with it.
Apr 06, 2009 | Acer Aspire 5315 Notebook
How to record sounds using external mic on acer aspire 4315???
go to the sound recorder available at start ---> programs ---> accessories then entertainment ----> sound recorder.
click on edit -----> Audio properties -------> default input device and change it to the external Mic you have connected.
let me know if this helped, good luck :)
Jan 05, 2009 | Acer Aspire 4315 Notebook
Acer aspire 4720z Built-in microphone only records loud static
You did great troubleshooting for your laptop. If the sound is fine and good for the headset, your sound card is probably not the problem. The driver aspect, should not be the problem either if it works with your headset. So herein lies the dilemma...the problem is most likely due to some physical componenent between the built-in mike and the computer case itself. You should take it to a laptop repair shop and see what they can do. It has nothing to do with the software or the sound card. It is the physical component of the built-in mike and speakers. Get that checked out and you should be good to go!
Nov 15, 2008 | Acer Aspire 4720 Notebook
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
