Question about Logitech LX 700 9674180101
Mouse battery charger
Can you please explain what the green llights are on the charger. I know
what the F and A lights are but what are the other two for
"A" is caps lock
"F" is enchanted F keys
"Arrow down" is scroll lock
"1" is Num lock
Posted on Aug 09, 2008
SOURCE:
How to know if the battery is already fully charge? will the charger be showing a green llight?
When charging the light is flashing, and after charging the light will last bright but not flashing Nikon battery charger
Jun 23, 2011 | Nikon Cameras
I have a pronto 2003 chair when charging batteries it we no move even if i charge is all nigh when i trurn joystick on it flashing one red llight an 5 green lighs what is the oproble
The error code means one of three things. First it could mean the batteries did not charge up at all. Next is unlikely ,but it also means too high of a charge voltage. The code also comes on when the charger is plugged in to charge and you turn the joystick on. The chair protects itself from driving off with the charger cable plugged into the wall outlet. One more possibility exists, the onboard charger could be bad and bad batteries. You need to have a trained electronic tech check this out.
Feb 14, 2011 | Invacare Pronto M51 Power Wheelchair
Recharger doesn't recharge
mcdevito75 here, The batteries in the mouse could be going bad, old.
Jun 29, 2010 | Logitech MX1000 Laser Cordless...
Green light on charging cradle is blinking green and mouse does not work
charger cradle lights are both on- when I pur mouse in charger lights on mouse do not come on.
Aug 12, 2009 | Computers & Internet
Stopped recharging
Two things: 1) This mouse and charger does not like rechargeables larger than 1800mAH. The light on the front will(sometimes) go red if you use a higher rated battery than the 1800mAH. You said you replaced the batteries, but might want to check their rating. 2) My mouse gets harder and harder to get a good connection when putting it in the cradle. Might be the contacts are getting dirty. When you put it in the charger, you should see the optical beam (red on the back) go out and the green light on the front turn on. If this doesn't happen, it isn't connected.
You do have the cradle plugged in and the batteries installed the right direction in the mouse? I know it's obvious, but the questions always have to be asked.
Aug 05, 2008 | Logitech MX 700 Mouse
Cordless mouse suddenly stopped working
I have had the laser fail in some of these mouse's. I have also had the batteries fail. I have seen cracked circuit boards from the mouse being dropped.
You mentioned that you changed the batteries. I am assuming that you tried new batteries that you know are good.
Technicaly, there are no servicable parts inside of these mice. If the fault is something very simple it can usualy be serviced.
Jerry G.
Feb 20, 2008 | Logitech Cordless Mouse
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
Logitech mx1000 Not charging.
I had the same problem with the mouse MX1000 not charging when it is on its charger.
Then, I realized that I forgot to plug the adapter for the charger - this charger is not taking its power from the USB port but from an external charger!
Once I plugged the charger, the mouse recharged without any problem.
I hope this helps.
This mouse is really great, once this question of recharge is solved.
Stephan
Oct 27, 2007 | Logitech MX1000 Laser Cordless...
Charging the Mx700 cordless optical mouse
I found the following:
Red light slow blinking: Battery Low, please put mouse in charger and charge;
When in Charger Red light Slow Blinking: No charging, please check and clean Gold Plated contacts in charger and Mouse;
When in Charger green light Blinking: Charging in progress
When in Charger green light Steady: Charging complete
When in Charger Red light Fast Blinking: Mouse detects overvoltage during charging! Please clean Battery contact inside Mouse, or replace rechargable batteries NiMh 1500-2100 mAh only
Oct 02, 2007 | Logitech MX700 CORDLESS OPTICAL MOUSE...
Open Questions:
See all Logitech LX 700 9674180101 Questions
Logitech LX 700 9674180101 Logo
61 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
