Question about Whirlpool RBS305PD Electric Single Oven
I have a Whirlpool Built-in Oven, Model RBS305 that emits a loud sound whenever it is on. Is it the cooling fan?
  • kristenes May 28, 2010
    Does it need to be replaced?
  • 523 Answers
Yes
Posted on May 27, 2010
Can I disconnect the cooling fan as it has become very loud. Whirlpool TrueTemp wall mount oven
Hi, it sounds like you need the fan bearing renewed or the fan unit. If you disconnect you will have to revert to just having an ordinary oven and adjust the temperature for cooking food accordingly for a oven without a fan.
Mar 09, 2016 | Whirlpool Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
My whirlpool oven (model rbs305) makes a loud noise whenever it is on. I can't figure out if it's the fan, or just extremely loud.
I would suspect that the blower is noisy its what i would expect to potentially make noise ...if fits in the back of the control panel and it comes on to cool the control board each time the oven is on.
In case it turns out to be the blower thats noisy the part number for it is W10176670
GENE
Sep 10, 2011 | Whirlpool RBS305PD Electric Single Oven
This oven has always had a loud fan noise when it was on or during cooling off. A couple of times lately I have turned it on and it has only had a quiet hum. I've turned it off and turned it back on a few...
Anonymous, we're sorry for the inconvenience. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 21, 2017 | Whirlpool GMC305PRS Stainless Steel...
My AEG competence oven is making a loud buzzing noise coming from the top fan? The food tonight was either burnt or under cooked? The buzzing is also loud when switched off/cooling down? Any ideas please.
I would suspect that the problem is caused by the external cooling fan located under the outside cooker cabinet housing, which continues to operate as the oven is cooling down if it is built in, you will have to remove it from the oven housing to access the fan
Dec 12, 2010 | AEG D4101-4 Electric Double Oven
In cabinet oven cooling fan does not work
it is the cooling fan if you have already replaced the thermal fuse on the back then replace the fan also shop around that price for the fan sounds high
Apr 05, 2010 | Whirlpool RBS305PDS Electric Single Oven
OVEN MAKES A LOUD NOISE WHEN IT IS TURNED ON. IT SOUNDS LIKE THE FAN IS HAVING TROUBLE TURNING OR SOMETHING.
This indigates worn or tight fan motor bearings, if it is a built in oven , then it could have an external cooling fan in addition to the oven fan, so you will have to determine which one it is.
Usually it means having to replace the offending fan motor, as lubricating only provides a short term solution.
Hope this helps.
Jan 09, 2010 | Whirlpool Ovens
Whirlpool built-in double oven model# RBD305PDB12
the humming sound is coming from the "squirrel cage" fan in the back of the unit, there may be some resonance vibration from the fan this issue should be addressed by a qualified service tech, the whole wall oven needs to be pulled out, i would have him check the fan.
Aug 27, 2009 | Whirlpool RBD305PD Electric Double Oven
Noise from fan when electric oven is first turned on
The fans are not normally repairable, but there is no problem obtaining replacements.
On a double oven, there are usually 2 fans fitted.
There is an external cooling fan usually fitted on the top of the oven, you would have to remove the top cover of oven to access it, and possibly the rear panel as well.
Then there is the fan fitted in the main oven compartment.
If you open the oven door as it is working, you should be able to determine if it is the fan oven or the external cooling fan that is the cause of the problem.
If you determine it is the fan in the oven that is noisy, then to undo the fan blade assy, you have unscrew the nut clockwise to remove it. as opposed to the normal way of undoing a nut.
Please rate my fixya solution.
Thanks.
Feb 09, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool RBS305PD Electric Single Oven Logo
308 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
