Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Hi I have a whirpool washer that is 7 years old, I replaced the agitators and the lid switch several months ago. However, today with a small load the water drained but it did not spin, making a loud clicking noise. What could this be? sounds like a coupler not engaging. Whirlpool model number LSR8133HQQ
  • 5,911 Answers
The most common cause of the symptoms you describe is a broken motor coupling. Whirlpool manufactured top loaders use a motor coupling in place of a drive belt and are known as "direct-drive" systems. No agitation, or spinning, associated with a grinding noise are the usual symptoms. The washer should still have the ability to drain, however.
The following link explains how to access the coupler and replace it, if necessary:
http://www.fixya.com/support/r3574231-replacing_a_motor_coupling
The part number is included with the instructions I provided. Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers I provided and go to your nearest appliance parts retailer. The coupler is usually sold as part of their in-store inventory. The average cost of a motor coupling is only about $15.
If you have any questions, or if the symptoms I describe do not match the problem you are having, please post back and let me know. I hope this helps you.
Posted on May 27, 2010
Washer will not drain, spin or agitate
If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professional.Check the drain hose to see if anything is plugging it. Sometimes small pieces of material go out with the wash water and become lodged in the drain hose.Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.http://www.mrsuds.biz/
Jun 10, 2013 | Maytag Washing Machines
Kenmore washer wont agitate
i would look at your lid switch this could be faulty
Feb 23, 2010 | Kenmore 22422 Top Load Washer
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
I have an whirpool (LXR6232EQ0) washer. The agitator does not move after the water fills the tank. Also on the rinse cycle, the agitator does not spin. Any idea would be appreciated...
This problem is commonly attributed to a loose or broken lid switch.
If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Jul 17, 2009 | Whirlpool LXR6432JQ Top Load Washer
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Won't spin/agitate and change cycles
If your washer fills and does not agitate or spin, it could be a simple lid switch problem. That's also probably the reason why it won't drain, either. Switching load sizes activates the pressure switch, which controls the level of the water in the tub (this is normal).
Locate the lid switch. It should be located on the right-hand side of the tub rim. There's a small hole in the rim where a small peg (called a lid strike) inserts from the washer lid to activate the switch. Check to see if the lid strike is not broken off. If the lid strike is still attached, open and close the lid to see if you can hear the switch "clicking". If no clicking noise is heard, take a small screwdriver and push it down through the opening to see if you can activate the switch (leave the timer knob pulled out when you do this to see if the washer starts). Double check the mounting screws to ensure they are tight. Sometimes the screws will come loose and the switch will not make contact with the lid strike.
Now some washers have the lid switch located on the left-hand side UNDER the washer rim by the lid hinge. This type of switch is activated by a rod on the lid hinge and fits into an opening in switch. Usually, this type of switch only requires an adjustment of the rod to correct any problems.
Please post back with your model number, so I can make sure what type of switch you have.
If you diagnose the problem and need to replace the lid switch, just click on the link below for complete step-by-step instructions.
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
I hope you find this information helpful. Let me know if you have further questions.
PS You do not have to drain the washer to replace the switch. If you need to drain it, however, post back and I can tell you how to bypass the lid switch to get the washer running to drain.
May 13, 2008 | Kenmore 24032\24036 Top Load Washer
Mo del RAB 1121EW1 serial number CG 402 1770
This is a direct drive washer so there is no belt. The drive coupler that connects the motor to the tub may need to be replaced.
Mar 05, 2008 | Roper RAB2121KW Top Load Washer
Kenmore agitates doenst spin
blaker, check the lid switch, no spin, no drain, usually a broken lid switch...Catriver...post back.
Sep 15, 2006 | Kenmore 23012 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
