Question about Toshiba 43HX70 43" Rear Projection Television
Image on screen looks concave(middle of screen looks farther away than left or right side.)
  • 3 Answers
Roseannmace,
Your TV is out of convergance. You'll probably noticed that there are red, green, and blue images. You'll need to determine if the problem is in the power supply or the convergance board. Usually, the convergance amps go bad and opens resistors. Do you know how to read a schematic and use a multimeter? You will also need to know how to remove the old parts and solder the new parts into the circuit board.
Ken.
Posted on May 27, 2010
Screen, Image, Lines,
Check and replace its LVDS cable [the cable that connects its T'Con board to panel]. Re-seat it once and check, before replace it. Any loose contact with either side of this cable; or the cable itself is damaged, can cause this fault.If you wish to get some details, check the site linked here. Pull up older posts.
Dec 07, 2013 | Toshiba 46LX177 46 in. LCD HDTV
My screen is concave and the red blue green colors are all 3 dimensioanl
Go to Menu then setup Look for Convergence if you do not see convergence listed,Then you have a blowed fuse on the Deflection board. It is the bottom board on left hand side it will have the FBT flyback Transfomer and on the Right Side of the FBT is 3 fuses right in a roll they will look lijke small brown retrangler Caps BUT are Fuses 0.6amp. It will be the Middle Fuse.
Partstore.com has them.
Heres another thing you can try with TV off Press and hold Vol- and CH- at same time hold untill TV comes on Now look for Auto Convergence.
Oct 03, 2010 | RCA HD52W56 52" Rear Projection HDTV
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Concave picture
sounds like the bulb is on its way out, they can be replaced for about 100 bucks.
Jul 25, 2009 | Philips 51PW9303 51" Rear Projection...
Vizio VX32L image distorts on edges like looking in a metal bowl.
I had a similar issue. Realized that the TV's "WIDE" setting was changed from "Wide" to "Panaramic". It was this panaramic setting that was causing the distortion on both sides of the screen. I had to switch it back to "Wide" using the "Wide" button on the remote to toggle back to "Wide" setting. Once I put it back to "Wide", problem went away. Hope this helps.
Jan 12, 2009 | Vizio L32 32 in. LCD HDTV
RCA P61960 Picture is concaved
this is the conversion chip or sometimes chips that cause these effects the chip or chips are about $30 each but labor is alot more $250 -$300
Oct 18, 2008 | RCA P61960 61" Rear Projection Television
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Red Blue and Green colors are not aligned and looks concave
replace fuse looks like cap next to flyback transfomer FL231 it will be the one in the middle.there are 3 of them next to FBT.
May 28, 2008 | RCA D52W19 52" Rear Projection Television
Color distortion
There are failures occuring in the scann and convergence circuits. This may not be feasible to service.
Jerry G.
Dec 14, 2007 | Sony KP-43T90 43" Rear Projection...
Toshiba 43HX70 43" Rear Projection Television Logo
77 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
