Question about Tokina 12-24mm /f4.0 for Canon
My Tokina 12-24mm /f4.0 for Canon got a little wet. When attempting to take pictures I get a ERR 01 message in my canon. Got the same error when I attached the lens to a second canon.
    Scholar:
  • 117 Answers
One of the internal circuits on the lens got more than a little wet. How long did you let it dry before putting it on the camera (which applies voltage to the possibly still wet circuit and probably shorted it out) ?. It sounds like a trip to Tokina is in order, unless you want to start a career as a repairman yourself
Posted on Jun 02, 2010
Tokina canon eos 350D error 99
1.Remove the battery, lens and CF card. Allow the camera to sit without power for 20 minutes and then reinsert a fully charged battery.
2.Turn the camera on and push the shutter button as if you were taking a picture.
3. If you don't get the error message reattach the lens and insert the CF card.
4. Check the below canon eos 350d service manual link:
http://goo.gl/ELh523
it will help you to save a lot of money
Hope it helps, Thanks
Apr 08, 2013 | Tokina AT-X 124 PRO DX Lens for Canon
Tokina lens problem
Try gently cleaning the contacts between the lens and the camera.
Sep 20, 2017 | Tokina 12-24mm /f4.0 for Canon
Err 99 message on canon 450d
CANON ERROR 99 1. Turn off the camera. 2. Remove the lens, battery, and CF card. 3. Allow the camera to sit without power for approximately 20 minutes. 4. Insert a fully charged battery, and turn on the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps: 1. Turn off the camera. 2. Insert the CF card. 3. Turn on the camera. 4. Format the CF card in the camera. 5. Depress the shutter button as you would to take a picture. Does the "ERR 99' message appear? If so, then the CF card is the most likely source of the issue. Try using a different card. If the message does not appear, please complete the following steps: 1. Turn off the camera. 2. Clean the lens contacts by gently rubbing them with a pencil eraser or soft cloth. Be careful that you do not let any debris fall into the camera body. 3. Reattach your lens. 4. Turn on the camera. 5. Depress the shutter button as you would to take a picture. If the "ERR 99' message only appears when one particular lens is attached, then that lens should be examined by a service technician. If you see the "ERR 99' with a different Canon lens attached, then the camera should be serviced. http://www.youtube.com/watch?v=WkXyLieNUDI - - - - - VIDEO & VOICE INSTRUSTION. Error 99
Aug 12, 2012 | Canon Cameras
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
My 60d finding ERR 01 with my tokina 12-24mm lenses. I try to clean the contact but after a few shoot the problem remain
I have the exact same problem, it's the aperture flex cable which have a design flaw. At 12mm the flex is stretched at maximum and over the years loses its flexibility and breaks. Mine works fine from 24 to 15mm. Below 15 the camera always reports err01. All flex cables in the tokina are welded -IMHO you need to take it to a professional.
Jun 20, 2011 | Tokina 12-24mm /f4.0 for Canon
I'm using Tokina 12-24mm f4 on my Canon EOS 20D.
Most likely something bad has happened. It out of warranty, usually its 5 years. This is a pro job, getting to anything inside a lens is a very special job. There are a number of places to send it out. Check http://www.acecam.com/srindex.html and write to one or two of the places for estimates. It could be $150 or more plus shipping and taxes. A new one is about $400+, you could check around the many on-line camera stores for a used one. Could be a simple electronic part or the iris blades are bad.
Jun 29, 2009 | Tokina 12-24mm /f4.0 for Canon
Err 01 on Rebel XSi
shutter struck, if the battery has no enough charge the shutter motor will not rotate fully,charge the battery and try.
Aug 31, 2017 | Canon Digital Rebel XSi Digital Camera
HI. Every I attempt to take a picture with my cam, I get a "Error 01" message. Please advise. Thank you
Err 01: LENS COMMUNICATION DESCRIPTION: This error occurs in the following conditions: When electronic communication with the lens cannot be established, after the EOS D300D is powered ON or when the shutter button is pressed halfway. When the lens diaphragm cannot be controlled during shutter release.
REMEDIAL MEASURE: Clean the electronic contacts on the lens with a clean, soft, dry cloth and check the mount interface switch on the body's lens mount for dirt or other damage. If this does not solve the problem, try another Canon EF lens or have the EOS EOS D300D examined by a qualified service technician. This error is similar to Error 84 on the D30.
rate me on this one...
thanks!
May 09, 2009 | Canon EOS 40D Digital Camera
ERR 01
Try remove the lens, it may be faulty.
Apr 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Err 05
In my case, I borrowed a camera and when I got it back, err 05 appears. I've located a bit of old orange juice which sticked one of the sensors - you can see the sensors when flash is popped out.
Feb 19, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Tokina 12-24mm /f4.0 for Canon Logo
398 people viewed this question
Top Tokina Cameras Experts
Are you a Tokina Camera Expert? Answer questions, earn points and help others
