Question about Mitsubishi WS-65809 65" Rear Projection Television
HD1080 65inc.mitsubishi my tv is about 5 years old i moved and had it moved to my new house thy tok out the inside when it was moved when it was put back together it does not go on,when u turn o the power butten the green light goes on and back off. the tv does not turn on at all,i had someone come out to check it they said it was a power suply,is there anyway i can find that peace and by it myself because they r chargeing me over 500 to fix it. i hope u can help?my name is Hope
  • pebbles2171 Apr 07, 2008
    iam trying that but green light just kees blinking,sorry
  • Mitsubishi Master
  • 8,617 Answers
Hello hope. Try pushing in the input and menu buttons on the set and hold them both in together for 8 seconds to see if the Led will blink a two digit code then let me know what that code says. I can get you a link where to get a new power supply, but that may not be your problem. Try this test an see what the led blinks if anything then let me know I will try to help you determine whats wrong. I am a specialist with mitsubishi projection units.
Posted on Apr 07, 2008
  • Sonny Berry
    Sonny Berry Apr 07, 2008
    Does it Blink continually without stopping? If so its due to 4 bad 1000uf @35v capacitors on the DM module. Thats what causes the power light to constantly blink. Change these capacitors and the set should work again. If you need more help let me know.
HOW DO I FIX A LIGHTING CHAIN THAT BROKE INSIDE THE HOUSING OF THE FAN?
You have to buy a new pull chain, usually two wire. Take light off fan and put new pull chain on as you take the old one off.
Sep 12, 2014 | Dryers
800 intruder, clutch slipps
If you have already adjusted the clutch cable with no luck try.Remove the clutch plat's and scuff them up with sand paper lightly and rinse them with gas and let dry. Put back in bike in the same order you tok them out should work like new if not thy are to worn and need to be replaced
May 30, 2011 | 2001 Suzuki VS 800 Intruder
The picture on my Mitsubishi WD62725 is starting to show some wavy lines and snow. We had a repairman come and he said that it needs a new chassis which would run around $550 and he said that it was not...
If the set is 6 years old I would not put $550 into it, but a new 60-65 DLP should only run you from 1200-1800. If you check around you will find alot of Mits DLPs on the internet for even less.
Jan 08, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a Mitsubishi WD-57734 and the picture when out on it. It's 3 years old and seems logical that the bulb burnt out. We still here the sound. I started looking at replacement bulbs and found other...
U used this tv 3 years?The tv been on and watches like 4 or 5 hours every day?Yes,than the tv projection lamp life is over.Require a new tv projection lamp.U also hear alot of cliking sounds,when tv first turn on?Yes,than the Ballast board is also dead.The Ballast board job is to help to ignite the tv projection lamp.
Nov 16, 2010 | Mitsubishi WD-57734 57" HDTV
Moved house and tv will not tune into inside
You could try a 15dB UHF amplifier that will usually feed upto 2 TV's they cost about £10-15 and usually have a pass through 240V plug and will work with the Sky Magic Eye.
Mar 18, 2010 | RCA Mikomi 5290925 15 in. LCD TV
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
"tok tok tok" sound from printer
The carriage can not move freely. Open case. Check for something slip in roller, or may be some material that block carriage moving.
Sep 11, 2009 | Epson Stylus CX4800 All-In-One InkJet...
Can't get a picture on TV screen
I think the tape is blank. I mean not recorded.
Oct 24, 2017 | Mitsubishi HS-U545 VHS VCR
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi HD 65" thin squiggly line in upper right corner that moves
Is the problem there on every source? DVD playback ok?
Suspect signal source  box.
May have bad connection since move.
Is the problem same on every channel,if source is cable direct?
Please provide more info if more help needed....T.
Oct 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
82 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
