Back to:
Tags:
Intel D845EPI  Motherboard
Moterboard (by 2 users)
posted by ian would on Apr 07, 2008
My motherboard will not power on but there is a green light that is on?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Jun 09, 2008
a little green light comes on the top of the motherboard, everything connected
Clarification Request
by Tabaluga, posted on Jun 13, 2008
If those steps did not resolve the issue, should I assume the motherboard is dead?
Best Solution
posted on Apr 09, 2008
Helpful (85)
Riinuka
Rank:Guru Guru
Rating: 88%, 33 votes
That green light indicates that the board is getting power. You should remove any excess components from the board, especially expansion cards like modems. Check to ensure the front panel header connections are properly connected (like the power switch, etc).
Lastly, ensure that all of the screws are in properly, so that the board isn't shorting out. As a troubleshooting step, you may try resetting the BIOS with the CMOS jumper to see whether a rogue setting may have caused the board not to power up.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on moterboard:
I don't want to Accept this solution
Can you Help with these Motherboards problems?
Motherboards
I need electrical conection drawing for D845WN Thanks for...
Motherboards
i still have this problem on unknown devices - Intel(R)...
Motherboards
hey i need help with my problem that im haveing with my...
Intel D845EPI (INTELKD845EPILPAK10)...
problem is related to vrm ic, may south bridge is faulty....
Loading problems.
Repair Service
Find Motherboard Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
