We have a new Rheem heater/air conditioner...we turned on the AC last night and just noticed today that a lot of water is leaking from some pipe that the installers left cut - which is directly on top of the furnace...is this going to cause any problems? water is very close to the wiring of the furnace and it's a lot of water! we called the installer and says he will try to come out tomorrow...but shouldn't we have someone look at it today? who can i call??
  • cdpedros May 27, 2010
    drifterK was a great help & quick reply!thank you so much!!!!
  • 4,924 Answers
If the water is leaking too close to the electric wires ..you just take a tube of some kind and for te moment just guide the water to drain away from the electric stuff...and by the way ..this is the condense water that results on the difference of the air temperature (humidity) and the cold parts inside the device ..and it is a normal effect ..but that pipe should have been longer and have a container or a bucket at the end to collect the drainage water
So ..untill the installer will be there ..just improvise something with a tape and a pipe ..to avoid the water to get to the electric part and cause a short ..circuit...
the effect is normal and there will be no issues ..
Posted on May 27, 2010
  • 5 more comments
    Hi there! thanks for your quick reply...
    so my husband is saying that the pipe that they cut - was the drainer from the old furnace that they replaced - the new drainer that they installed - there is no water - it is completely dry!
    my husband just did what you mentioned and put a temporary pipe from the old drainer - and we are axiously waiting for this guy to come in tomorrow.
    Honestly - what a mess!
  • Catalin Turcu
    Catalin Turcu May 27, 2010
    if teh new one has no water in the draining ...than it is probably a mistake ...instead of inserting to the new pire ..they put the old one to the unit ..and it is draining from it ...probably a mistake ..and all that will have to do is to change them ...cause if it is in function ..there is no way to end up dry ...cause the condense is forming no matter what ..
    So all in all do you feel we have a serious concern on our hands? is there a fire hazard? that is the only worry i have in my mind!
    my husband is upset with the installers lack of response, my only concern is that this won't cause a fire.
  • Catalin Turcu
    there is no fire issue ..but if the water gets into the electric wires that are not isolated..( I mean at the plugs or other join point ) it may cause a power black out ..
    anyway ..if it is a little handy ..he should take a look and see if I'm right and they mounted the pipe but connect the old one ..by mistake ...and if the pipe have a simple screw-able join ..just screw it in place well and that will fix the issue without any need for installers..
    unfortunately it is all connected inside the furnace - we can only see the pipes that come out from the furnace - new one is on bottom of furnace - and the old one is above the furnace - my husband grabbed a broom stick and some duck tape and has the water going down the drain - so we should be fine - he just doesn't know now if there is any leakage inside the machine!
  • Catalin Turcu
    there isn't any problem like that ..if there was..there should be water in the both pipes...even if it had a leak inside the new pipe should collect some of the water even if it leak ..so if it is dry ..it is not connected at all..and the drainage remained on the old one ...
    even so ..this water it is the actual inside formed by condense and there is no real danger until tomorrow or when those men will came ...if you collected the water ..it should be fine ..
    This is great help (and helped ease my mind for the night) thank you VERY much for your help!!
Installed a new rheem water heater last night and still no hot water. It has power thermostat set at 130.
Turn off the heater then open the bleeder valve on top of the tank to let the air escape. Once all of the air has been bled off, faucets included then turn your heat back on.
Jun 14, 2017 | Rheem Water Heaters
Rheem water heater leaking water from relief valve pipe
the relief valve is replaceable . if it isn't leaking I would not worry about it
Feb 19, 2016 | Rheem Water Heaters
I have a 2002 Ford Taurus Sedan and I notice there is steam coming out of the hood. The steam is definitely not smoke. When I open the hood the car doesn't seem hot but I notice there is a little...
I'm guessing you have a minor anti-freeze leak.The condensation on the air conditioner piping is normal,as your AC works a lot,every time you select defosteror some other positions on your heater.
Check for a teeny leak coming from a hose on top of the engine. don-ohio
Sep 03, 2011 | 2000 Ford Taurus
The furnace is leaking water when the air conditioning is on... rheem 90plus edition
It sounds like the condensate drain or the 3/4" pipe that comes out of the bottom of the coil is plugged...then the water runs all over...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 21, 2010 | Rheem Heating & Cooling
Also, the copper pipe that is supposed to carry cold water into tank is very hot, hard/if not impossible to tell cold pipe from hot water pipe. I was told my Rheem AC has an energy feture that release the...
That is normal, the heat just rises from the hot water, the pipe on the right should be cold and if you were to run hot water anywhere in the house it will immediately cool of the cold inlet pipe and you can feel it
Jun 26, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a rheem 41v50 water heater its leaking out of the top is it a major problem or can it be repaired?
If the water heater itself is leaking it most likely cannot be repaired. If it's leaking at the presure/temp relief valve it could possibly be dangerous and needs immediate attention. If it's the pipes leading to the water heater then it's most likely worth repairing. If the tank is old and rusty it's best to replace it. If it's fairly new it might still be under a manufactures warantee. The last I knew Rheem had warantees up to 11 years, depending on the model water heater. With out actually looking at the water heater it's almost impossible to give a more definite answer, I hope this helped.
Mar 27, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water leakage from internal unit of split AC
Draim pans do get dirty and partialy block drain pan. If possible take a shop vac and gently **** out the drain line. This will pull the restriction out of the line and help clean drain pan. Rusty
Jun 05, 2009 | Heating & Cooling
Have a rheem central air conditioner heater. I
gas valve could be clogged it has a screen in the side of the inlet, check this first if not it could be the gas valve itself,, make sure the gas valve is turned on also, sometimes people turn them off and for get the handle should be in line with the pipe not across the pipe
Apr 27, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem small 6 gallon water heater vibration/noise
If the water heater is working fine than I would not worry about the function of the water heater. What the problem may be is that some of your WATER LINES HAVE MOVED, AS THEY WERE NOT SECURED PROPERLY. The sound you may have heard was the Copper or PVC(Plastic) lines just getting back comfortable. I Suggest checking that your water lines are secured about every 3 or 4 feet with the proper ancjhor....Metal for metal pipe, copper for copper pipe, etc. Sometime as in my house, pipes are run through a hole drilled through a stud or a piece of wood, usually when hot water is run through this pipe. You can here an expansion of the water line interacting with the pipe expanding, if the hole in the wood was not drilled big enough......Experience of remodeling a very old house.......Joe
Dec 31, 2008 | Rheem 81VP6S/430126 Water Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
