Question about Traxxas Rc Revo Nitro Monster Truck
Revo 3.3...engine doesnt stay on...
I have a revo 3.3 with a stock Trx 3.3 engine...i had it for about 2 years now and the truck only stays on when theres power from the ez start wand...if i take the wand off or turn it off, the truck turns off. Does anyone know why and how to fix it...please help..Thanks
  • 56 Answers
Could be a couple of things. Firstly the glow plug may need changing or youre running slightly rich. If you was replacing the glow plug you should retune the engine anyway. When the fuel is entering in the engine where the glow plug is theres either to much fuel and flooding plug out or the plug is not up to the job of burning the fuel. Replace plug and retune. You have had car for two years so guessing you know how to tune the engine.
Posted on Jul 05, 2010
Testimonial: "Thanks...I did what you told me and it works perfectly now."
Cant get my traxxas revo rc car to stay running, need to know how to adjust the idel speed and the high and low speed needle
hi speed needle is the big one right below where fuel line goes in carb...the lo needle is on the end of the carb. slide..when you pull trigger theslide comes out...on the end of it is a screw thats the lo needle..the idle is on the carb. neck sorta on the back side.
Sep 17, 2013 | Traxxas Rc Revo Nitro Monster Truck
Poor casting ability
Remove the left side plate and set the little plastic things ( I think they are yellow) so they are against the inside..they should kinda snap inwards and stay there...
Found a video ( not well made but it shows how to access the brake system).. you will see the SIX little yellow plastic brake adjusters... start with moving FOUR (4) - opposites of each other - of them inwards towards the spool shaft.. they should "click" inwards and stay there...CAST carefully the next time.
.. how to access brakes on abu garcia orra sx and revo lp baitcast reels
Jul 16, 2017 | Abu Garcia REVO STX Generation 3 Casting...
Troubleshooting
Bad glow plug. Dead battery in ignighter. No fuel going to carb.
May 07, 2013 | Traxxas Rc Revo Nitro Monster Truck
I downloaded microsoft silverlight but it did not install correctly so when I tryed to uninstall it or remove it from Add or Remove it wont remove it because it says that I am having problems with my...
Download and install Revo Uninstaller from here: http://www.revouninstaller.com/start_freeware_download.html
1. Under the Freeware column, click Download.
2. Save file and install program.
3. Open Revo Uninstaller and wait until if finds all of your installations.
4. Fine Microsoft Silverlight and select Remove.
5. Select Safe. (Make sure you have System Restore on)
6. Delete the registry entries that Revo suggests.
7. Delete the files and folders that Revo suggests.
8. Finish the uninstalling by clicking next and then clicking finish.
9. Reinstall Microsoft Silverlight.
Good luck and thanks for using FixYa.
Mar 08, 2011 | Dell Computers & Internet
How do i tell what model traxxas i have. also am looking for assistance putting it all back togerther.
If the engine is a Traxxas it will have TRX 3.3 on the side of the engine block. All of the manuals are available online at www.traxxas.com.
Sep 20, 2010 | Traxxas Rc Revo Nitro Monster Truck
Traxxas revo 3.3 running problems
Maybe running to lean or to rich. When you accelerate put youre hand where the exhaust is and you should get a light spraying of unburnt fuel over hands(lovely!). If you do you may be able to screw in high end needle in a bit and i mean just a bit. If you hear the engine note raise a bit with a slightly higher pitch then you are running to lean and you will want to unscrew the high end needle valve asap.
Also check youre idle screw and make sure thats not closing the carb and stopping any airflow into engine. Let me know how it goes.
May 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
3.3 revo hard to start after started it will not idle and when it dies it does not want to restart. This did not happen until I drve it thru alot of wet grass last year
Hi
2 stroke engines are very simple. If there's fuel (under pressure) and a spark it will run. Check the glow plug by trying to start it with glow plug removed but still connected and touching the engine body. If the little center wire glows bright red, then it's OK. Only do this for a second or so. If the plug is OK then it has to be a fuel problem. Traxxas has a long history of cracked gas tanks. Good luck
Apr 30, 2010 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Revo 3.3 shifting problem
you might need to reset the opti drive. turn the power on with the engine still off and hold down the optidrive button for 5 sec. see it that works.
Jun 24, 2009 | Traxxas Rc Revo Nitro Monster Truck
Traxxas Rc Revo Nitro Monster Truck Logo
540 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
gbob59
cwradio73
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
