Question about Sport & Outdoor - Others
Travel trailer slider motor runs but it doesnt move
I tried to run the slider out on my trailer to get it ready for a trip. The motor runs but the slider doesnt even begin to move. it is an electric slider, very small couch size only. Could it be off the track? It is a 2000 Sandpiper 23' dual end popouts, single slide travel trailer.
    Problem Solver:
  • 5 Answers
Go too walmart
Posted on May 27, 2010
I have recently purchased a rv travel trailer and noticed the a/c sometimes trips breaker. Fan runs fine assuming it's compressor sometimes draws 45 amps and other times runs fine.
Yes, or it can need to be recharged. It's been a while since I worked on RV'S but I think they run off an ammonia system and makes them a little weird to work on from the DIYers perspective. I'd suggest have it serviced at an RV place. Good luck.
Sep 13, 2015 | R-Vision 2010 Trail-Lite Crossover...
Wiring diagram for salem by forest river travel trailer
Try turning them to the off position then on again that should reset the breaker. When they trip sometimes they move so little you can hardly see it.
May 03, 2014 | Cars & Trucks
Breaker keeps tripping on generator when I turn on ac in travel trailer
4KW is marginal for HVAC compressor. Breakers get weak with time. Assuming th gen is running properly and the correct voltage is available. A HVAC unit can take 6 times the start current than it takes to run, so it is possible the inrush is too much
Sep 02, 2013 | Makita 9 Hp 4,300 Watt Portable Generator...
Recently purchased a 4400W generator to operate travel trailer primarily and on occasion my ac unit. Connected the generator to the travel trailer, then ran the a/c, everything going well, then the circuit...
What size circuit breaker is on the generator that is tripping? You'll need a 20amp for AC alone, then consider other things that are drawing current when RV plugged in like , converter, fridge etc that may be drawing current at same time. Make sure fridge is on propane, as well as water heater if you have electric element option on water heater. AC may only draw 12-15 amps when running if good and clean and wired properly, but will draw 17-18 amps when compressor kicks in. Perhaps generator not designed for that surge?
Aug 28, 2011 | Dometic Rooftop RV Air Conditioner
Ac fan will not run on high setting , manual or auto . when unit calls for high setting fan shuts down . Compressor continues to run and trips breaker in trailer . Someone thinks it may be the motor, but...
Most probably its weak motor.When the motor gets weak it trips/ stops on high setting.On high setting motor needs more power to run the fan.Try lubricate the motor .You may need a few drops of oil on the fan motor bearings. As they get older they get dry and gunked up. If you can see the bearings a few drops of oil may help. --------- Because the fan operates on medium and high, so loose wire or faulty fan switch is very rare to cause this problem.-------- As per the problem , it requires motor to be replaced.--------- This will help.Thanks.Helpmech.
Jul 29, 2011 | Dometic Rooftop RV Air Conditioner
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
THE BREAKER CUTS OUT ON LOW AND HIGH
Current draw to high....BREAKER COULD BE WEAK..
Aug 18, 2009 | Dometic Rooftop RV Air Conditioner
Slide out will not slide out
Thanks, I fixed the problem so pleasse take me off your email list
Dec 25, 2008 | Computers & Internet
Unit comes on, then throws breaker
Fan should start at the same time as the compressor. If the fan is not running the pressure could build in the system and cause the breaker to trip. Your fan motor may need replacement, or lubricated if it is not a permanently lubricated motor bearing type. Oil ports will be located on the fan motor for front and rear bearings . There may be a dirt plug in the oil ports.
May 31, 2008 | Dometic Rooftop RV Air Conditioner
Sport & Outdoor - Others Logo
202 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
