Question about Samsung HL-R7178W 71" HDTV
Just put in a new lamp as I thought that was the issue but it is still turning off picture after about 1 minute. then all 3 lights flash on the center on off button. what could be the issue?
  • Forrest E May 27, 2010
    Any whining just before this happens? if so its probably the colorwheel!
  • 25 Answers
If u hear a whining sound before it starts cutting off then its the colorwheel,partstore.com
Posted on May 27, 2010
Lamp light flashes then stops. no picture. samsung HLS4266WX/XAA
Was the trouble exactly the same before lamp and wheel were replaced?
If lamp comes on for 3 minutes what do you see on the screen?
the more you tell me the better I can assist you.
Mar 14, 2012 | Samsung HL-S4266W 42" HDTV
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
We have a Samsung HL-T6176S DLP TV I currently have no picture. When I plug the TV in after a few minutes all 3 little lights in the lower left corner of the TV flash on and off, and still no...
The "LAMP" LED light indication flashes or stay on?The tv projection lamp been inside the tv like 1 1/2 or 2 years,tv been on and watches tv like 4 or 5 hours a day?Yes,than the projection lamp life is over.Tries websites like Partstore.com,Ebay.com to buy a new projection lamp for the replacement.
Oct 22, 2010 | Samsung HLT6187SAX 61" DLP HDTV
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Sony KDF-E55A20 Lamp Shut Down with no blinking lights
If you TV is about 2 1/2 yr you probably need a new lamp they only last about 3 yrs. Mine popped one night and now picture comes in for about 1 min and goes out, I ordered a new lamp today they run $199. There is also a know issue with the thermal fuse. The part cost about $3 and if you know a lil about electronic you can replace it yourself
Nov 11, 2007 | Sony KDF-E55A20 55 in. LCD Television
DLP TV turning on and off automatically - Mitsubishi WD-52327
1. Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V part # 181P732040 on the Power PCB part # 930B929001
Sep 18, 2007 | Mitsubishi WD-52327 52" Rear Projection...
Samsung HL-R7178W 71" HDTV Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
