Question about Fuji Discovery 1000 35mm Point and Shoot Camera
My brother's Fuji Discovery 1000 35mm Camera met with a small accident. The latch on the cover is broken. I don't know how old the camera is, but would like to know if it can be fixed, and if so, what is an estimate of cost.
    Brigadier General:
  • 3,006 Answers
Parts are no longer available, and like almost all 35mm compact cameras (and many SLR's), your brother's camera is utterly worthless so repairs are totally uneconomic to repair unless you can fabricate a replacement latch yourselves.
Although this may sound gloomy, it's not. The silver lining is that you can easily find a similar or better model on your local FreeCycle or Freegle groups for zilch. There are millions of perfectly good 35mm film cameras lying unused at the back of peoples cupboards and drawers and the majority of owners know they're near worthless so haven't even invested in the replacement batteries that many need.
Posted on May 28, 2010
Testimonial: "Thank you for your answer to my question. You were very helpful as I would have tried to finds someone in my area to fix this camera."
I came across an old Fuji Discovery 900 zoom plus 35mm camera and it has these 3 small pieces that came with it (and are stored in a pouch on the shoulder strap of the camera case) They have symbols...
They are to tell you what exposure to do it at, you match the weather with the symbols and that should tell you what exposure to do the camera at.
Mar 01, 2011 | Fuji Cameras
Broken battery cover latch
The battery cover latch is broke how can we repair it
without having to use duck tape?
Apr 23, 2010 | Fuji FinePix S7000 Digital Camera
Camera door thats holds battery small grey latch is broken
Try partstore.com they might be able to solve your problem. Also look at the latch and determine if it is attached to the front of the camera case or the back of the camers casing I am assuming it is attached to the back then you might consider caling HP back and ordering the Back or Front cover Assembly. Small pieces like this usually don't come by themselves you have to order an assembly, so when when u call for parts ask for Back cover assembly or front cover assembly, which ever it is attached to or apart of. Asking for a perticular piece they will not usually know what you need. You have to talk to them in technical terms.. Hope this helps you out...
Sep 21, 2009 | HP R967 Digital Camera
Little bit on battery cover broken. So won't close!!!
Those parts are not easily attainable. You will need to send it in for servicing. You could also buy a parts camera and try a DIY repair, but that may void the warranty.
Apr 14, 2009 | Fuji FinePix F45FD Digital Camera
I can't get my fuji discovery 1000 zoom to read film
A camera is for recording images onto film, not reading the film.
Jul 18, 2017 | Fuji Discovery 1000 35mm Point and Shoot...
Battery cover
I had a look at my S5000 and see what you are talking about. Those tabs are part of the inner shell, likely expensive to replace if even cost effective. In the past, I have cut the broken tabs off, leaving a flush surface. I then drill small holes and insert large head screws that I file to match the door tabs. It does require some finite work but is possible without disassembly of the camera.
Jan 22, 2008 | Fuji FinePix S5000 Digital Camera
My camera wont turn on
This camera has a security switch in the battery door maybe the actuator for activate it, is broken you can block this switch with a paper or somethingh this switch is located in the battery cover ok. I had a camera with same problem aftet block the switch it work ok.
I hope you can fix yours.
Aug 12, 2007 | Fuji FinePix A360 Digital Camera
Faulty Latch Sensor
in the bottom corner of the latch there is a little piece of plastic on the hinge that pushes a switch that tells the camera the latch is shut if thats broken off thatll be the problem id shove a piece of a matcher in to see if it does the trick and if so its a new latch or leave the matcher :) 5
Sep 12, 2005 | Fuji FinePix S1 Pro Digital Camera
Fuji Discovery 1000 35mm Point and Shoot Camera Logo
110 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
