Question about Homelite Mighty Lite Lawn Trimmer
When engaging the throttle. the engine bogs down and quits. the fuel mixture is 50/1. air filter is clean. not sure what the problem is?
  • 420 Answers
Lack of fuel causes the symptom but the root cause may be fuel lines that are cracked and allowing air to mix with the gas or there is a restriction such as a plugged filter (inside the tank) or at some other point in the system from tank to engine. while the trimmer is idling if you see air bubbles in the fuel line replace all lines and filter. if there are no bubbles it could be remedied by a complete flush and cleaning of the fuel system from tank to carb.
Posted on May 27, 2010
2016 Kymco Super 8 50 2T carburetor tuning
Hi, Jason if you have changed your engine size, fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve, and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" you're not getting enough fuel.
1. Close to 1/8 throttle is managed by the air screw and pilot/slow jet.
2. 1/8 to 1/4 throttle is managed by the air-screw, pilot/slow jet, and throttle slide.
3. 1/4 to 1/2 throttle is managed by the throttle slide and jet needle.
4. 1/2 to 3/4 throttle is managed by the jet needle, needle jet, main jet, and air jet.
5. 3/4 to wide open throttle is managed by the main jet and air jet.
6. A wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, the engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Kymco Super 8 50 2T BBK Tuning Help 49ccScoot com Scooter Forums
Carburator Theory and Tuning
KYMCO SUPER8 50 2T Service Manual
Kymco Scooter Parts ATVs Scooter Parts Performance Scooter Parts...
http://absolutelyscooterparts.net/pdf/CGEN_dawg_scooter_manual.pdf
Jan 24, 2018 | 2013 Kymco Super 8 50 2T
Bike won't run smooth.
Hi, Joe if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
1. Closed to 1/8 throttle is managed by the air screw and pilot/slow jet.
6. Wide open throttle is managed by the main jet.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Carburetor Set up 101
KTM 250 SX 2005 Repair Manual
http://www.partsfish.com/page/oem-parts-for-ktm
KTM 250 XC Owner Manual
May 19, 2017 | 2005 KTM 250 EXC
Bogging at mid range sr 125
Hi, Anonymous if you have changed your fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
If you are running lean, spark plug electrode color is white, engine runs hot and feels like it is starving for fuel you need to go up on the jet size or move the c-clip down one notch. If you are running rich, spark plug color is black or dark gray, engine runs cool, and bogs down when accelerating you need to go down on jet size or move the c-clip up one notch. When your carburetor is properly tuned for maximum performance your spark plug electrode will be a light tan color like coffee with cream. If you prefer fuel economy over performance you can go down on main jet sizes until a satisfactory level of lower performance is acceptable versus MPH, your spark plug color will be whiter and your engine will run warmer. These tuning adjustments will only make improvements if your intake and exhaust system have no air leaks or sealing issues and the entire electrical system is in proper working order and you have no mechanical issues. For more information about your issue and valuable "FREE" downloads that you will need please click on the websites below. Good luck and have nice a day.
UPDATED 2005 YZ125 bog issue with videos
http://service.tanga-moteurs.ro/data/Yamaha%20SR%20125%20'97%20-%20Service%20Manual.pdf
OEM parts for Yamaha
YAMAHA SR125 Owner Manual
Sep 13, 2013 | Yamaha Motorcycles
Bogs down throttling
Hi, Anonymous it should be noted that your performance issues are not electrical ie. faulty charging system, battery condition, and connections etc. If your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" your not getting enough fuel.
MototipsTV Replacing Float Cleaning Carb
YAMAHA YZ125 Owner Service Manual
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Jul 26, 2013 | Yamaha YZ 125 Motorcycles
1985 pw50 carb adjustment specs
Yamaha PW 50 checking carb
YAMAHA PW50 Owner Manual Adjusting The Carburetor Adjusting The Engine...
2009 YAMAHA PW50 REPAIR SERVICE MANUAL PDF DOWNLOAD Download Manuals...
Yamaha PW50Y Owner Manual
Feb 21, 2013 | 2005 Yamaha PW 50
163FML (CG200) bogging at low rev
Hi, Marcus and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Bogs when open the throttle fast
Motorcycle Message Board Motorcycle USA
boging and half throttle
boggs down when accelerate aggressivly to full throttle Pit Bike Club
Why is the engine bogging under acceleration Suzuki FA50 Moped
Bike dies when you give it throttle
Mar 17, 2017 | Motorcycles
Saw idles somewhat but bogs down and quits (no power) when using throttle
check fuel filter, fuel tank vent, air filter, main jets could be blocked, leak in the fuel line between carb and tank, diaphragms fatigued in carb.
Mar 21, 2012 | Husqvarna Chain Saw Handle Models 50 51...
Vespa ET2 50 Motorcycles carburetor tuning
Hi, Juan if you have changed your engine size, fuel delivery system, air filter size or flow rate, mufflers or exhaust system or a significant change in altitude your carburetors need re-tuning and if your fuel system (gas tank, filters, fuel valve and carburetor) is contaminated with ethanol sludge, varnish, rust, dirt, water etc. or your bike has been sitting for months or years without running these components must be "PROPERLY" cleaned and reassembled "CORRECTLY" before any adjustments can be made. Tuning your carburetor is fairly simple once you understand the basic principals. You engine is a simple airbox sucking air in and blowing it out, it is finely tuned at the factory for maximum performance once you upset that delicate balance by changing air filters, camshafts or exhaust systems your performance may go down the and the engine may run poorly, you need to compensate the air-fuel mixture in the carburetor in order for the engine to run smoothly and at peak performance. If you are running multi carburetors you need to sync them first and make sure your air cleaner element is clean and dry for paper elements or lightly oiled for foam and meshed elements and properly installed. Here is how and where you compensate trouble: "TIP" if your engine "BOGS" you're not getting enough fuel.
Vespa ET2 50 cc Scooter Custom Performance Carburetor Carb Stage 1 3 Jet...
STEP 1 ADJUST IDLE MIX FASTER SCOOTER EPISODE 4
VESPA LX 50 Workshop Manual
Vespa VESPA ET2 2001 Parts
Vespa LX 50 User Manual
Dec 16, 2017 | Vespa ET2 50 Motorcycles
Throttle bog out
hi,this may help,check the inline fuel filter and the air filter,if it has been sitting that long the fuel filter may have gummed up(a slightly gummy residue left behind after fuel evaporates) the engine will run ok at low and medium throttle but the filter will be quite restrictive once the load goes on,change the filter and clean the air filter and you might find the problem disappears...hope this helps...cheers
Jul 28, 2009 | 2001 Yamaha WR 426 F
Bogs down at 50 mph or over
this is an air intake problem check the air filter is clean also check air filter is the same model as original as some air filters require a carb retune to function properly
hope this helps
May 26, 2009 | 2001 Suzuki VZ 800 Marauder
Homelite Mighty Lite Lawn Trimmer  Logo
625 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
