I think i have problem with my OS ...it showing disk error message.So is their any other way i can get in to my OS
    Brigadier General:
  • 4,044 Answers
Unless it's the Hard Drive that is not showing up, you can go into the Bios and set the boot order to bard Drive Only or hard Drive First and to not stop on errors to attempt to bypass the problem. If it is the hard drive, or any other drive for that matter, check all of the drive connections to make sure they are fully seated to the mother board and to the drive.
Posted on May 27, 2010
What do i do when my computer shows the message non system disk or disk error
If your hard disk can detect on BIOS Setup,There is a problem on your hard disk. Whether the installed OS is corrupted or the hard disk itself have bad sectors. Sometimes Master Boot Record (MBR) issue. Try to make fresh install of OS
Feb 23, 2013 | HEWLETT-PACKARD 620 XT964UT Notebook PC
I have a toshiba A215-S7437 and i get the error message read disk error when trying to boot up
A disk error is a fatal error on the hard drive, SMART monitoring will show you this in the BIOS, restoring to factory settings will not cure it.
You need to get a new hard disk and reinstall your OS
Apr 25, 2012 | Toshiba Satellite A215-S7437 Notebook
How to solve blue screen problem
I think it maybe Virus Or hardware ! In hardware, memory Or Hard disk is not good , it always show blue screen . But it sometime shows Os error . i think u must check out HDD for Virus .
Jun 07, 2011 | Computers & Internet
Write Protected USB
hi Not only your pendirve your computer system is also affected by virus . please check your pendrive with any other computer .before you connected open your pendrive format your pendrive with any other computer. if it will not work you have go for any new pendirve. bye
Jun 16, 2009 | Disney High School Musical Mix Stick 2.0...
Hard disk formetting
hi,
I think low level formatting should do the trick. you can download it and its free. In your case try to download the DOS based version. This type of formatting erases the entire disk clean.
Jun 07, 2009 | Microsoft Windows XP Professional
Hello, I have an IMB thinkpad 600E 2645. Previously, i was getting error 00161 & 00163 this was resolved. then i received error 173 & 163 which was resolved as well. It appeared that a piece fro mthe...
there probably is a problem with ur O.S.this is the reason y ur system is not bootin up.try installing O.S from a different C.D.U can use the same serial number as long as you are using the correct installation C.D.u can also go for a diffrerent O.S if u can get it arranged.i think installing a new O.S sud solve ur problem
May 03, 2009 | Computers & Internet
Detecting , not open shows err Please insert a disk into drive D:
i think your driver is not comptaible with your OS???
just search that driver in google for your OS
Mar 29, 2009 | Electronics - Others
Got off lease also, with no OS it won't boot
You may not install a working Hard driver from one compuyer to another unless every component is exactly the same. All windows OS look at the hard ware to stop a person from  moving an OS for one syastem to another. Reinstall the OS of you have the disk,or use a free OS or co to the website and get a reinstall disk if a name brand computer that came with an os.
Jan 20, 2009 | HP Compaq Business d530 Small Form Factor...
Got following error: Load Error! Press any key to reboot
This problem is indeed caused by a faulty MBR but there are solutions other than zero-filling the drive.
If you can get access to a RipLinux CD there is a little utility called Testdisk that will write a new MBR code to the first block of the drive. I just did this on a Sony PCG-K15 this morning (after cloning the drive just to be safe) that was giving the same error of "LOAD ERROR- Press any key to reboot" and it worked like a charm. The machine booted right up.
Hope this helps...
May 09, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
