Question about Shuttle AV42 Motherboard
Motherboard...and freezing Hi! I did look those signs on motherboard but did not find any...atleast not from the spot i should put them in, did u mean from all over the board or some specific spot? And other problem: My pc keeps freezing everytime i do something that requires more memory usage...i can do stuff on Internet but cant play any games longer than 10 minutes. I checked the temperatures with Everest and it showed rising temp from about 50C to about 90C (even if fans are running perfect) after playing some games which needed more memory. Is it possible i damaged something while cleaning pc? I did Remove cooling fan from motherboard to clean it from dust... Thank You!
  • 655 Answers
The portion between CPU and CPU sink must be clean, to work well for CPU cooling. So remove the fan gently and clean the surface of sink which touches on the CPU, also clean the CPU surface which touches on the sink.
hmm regarding connection if you can post a picture of your board i will mark on it where to make connection.
Thanks
Iqbal
Posted on Apr 07, 2008
SOURCE:
Dell e5520 freezing
Possibilities:
1. Dying power-supply is creating unstable voltages
2. Dying capacitors on motherboard are unable to stabilize voltages
3. bad RAM (compare to writing in pen on greasy paper -- nothing is realiably being recorded)
4. bad spots on disk-drive (computer is spending too much time trying to write to those "bad" spots)
5. other "dying" issues with the motherboard
Try:
1. different power supply
2. if you have more than one stick of RAM, remove one and test-drive. Repeat with the other stick(s).
3. Try different RAM.
4. Force CHKDSK ("Check Disk") utility to scan *all* of the disk-drive.
5 Inspect the motherboard for bulging/leaking capacitors.
6. Replace the motherboard.
7. Replace the whole computer.
May 27, 2014 | Dell Computers & Internet
Gateway laptop,mx6912 has a 02FC error
PU fan died, or atleast the motherboard believes it has. That's what the error means, but can be bypassed by hitting F1 at the boot screen..
Aug 22, 2011 | Gateway Computers & Internet
New build with asus M4A79XTD EVO and AMD Phenom II X4 965 Black Edition Deneb 3.4GHz 4 x 512KB L2 Cache 6MB L3 Cache Socket AM3 125W Quad-Core Processor. When you hit the power button, the fans start but...
Hello
It almost sounds like a mistake at the pc start switch and reboot switch.
Check that you have your pc start wires from the front start button of the case, in the correct spot on the motherboard.
Also remove the memory sticks and reseat them.
The green light on the motherboard is good it means your getting power from the power supply.
The start and reboot switch wiring can be tricky if one plug is in the wrong spot on the motherboard.
Feb 03, 2011 | ASUS M4A79XTD EVO Motherboard
Can I put a 3.0 chip on the 845PE Max motherboard?
If you are speaking of usb 3.0 most likely not atleast until they release and add in usb 3.0 card that is pci not pci express
Sep 24, 2010 | MSI 845PE Max (MS-6580-040) Motherboard
Freeze
Usually phone freezing is a sign of the software corruption. Re installation the cell's software will solve the problem. If the software updation doesn't solve the problem then there could be the problem with the motherboard..
Hope this has helped you.. Please rate the answer.. Thanks..
Jul 13, 2010 | Samsung SGH-S5230 Cell Phone
800MHz Dual Channel RAM on Intel D945GNT
YES U CAN BUT IT WILL ONLY RUN AT 667MHz.RichardM69
Nov 30, 2008 | Intel Motherboard
FREEZ
hi..!
you mean ,it does'nt work?
will before we install a new OS,we have first to know the requirements needed of that software,Like the memory,the speed of PC .now if we have all the requirements needed,thats the only time we can intall the software.
Mar 27, 2008 | Asrock P4I45GV...
Motherboard BIOS
Hi, your motherboard and Bios settings are both ok.
The problem is most likely your hard drive. I reccomend you check this by pressing the delete key repeatatadly at start up to enter the bios settings. at the first screen you should see if your hard drive is recognised [ primary master]. It may be time for a new drive or for a reinstall of your operating system.
Regards mistyman
Nov 06, 2007 | Computers & Internet
Open Questions:
See all Shuttle AV42 Motherboard Questions
Shuttle AV42 Motherboard Logo
101 people viewed this question
Top Shuttle Computers & Internet Experts
Ekse
Alun Cox
pvc73
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
