Question about Gateway 702GE PC Desktop
How do i install the cooling fan for a gateway 702ge
  • Gateway Master
  • 12,061 Answers
Http://www.retrevo.com/support/Gateway-706GE-Desktops-manual/id/12911ci152/t/2/
http://gd.panam.acer.com/s/PC/R/3726/4327nv.shtml
http://repair4laptop.org/disassembly_gateway.html
Check out these links, they will help you.
www.ehow.com/how_6179713_install-cooling-fan-gateway-laptop.html - United States -
Posted on May 27, 2010
  • 23 Answers
Assuming we are talking about a case fan, bring out a flashlight and possibly a magnifying glass, and start sweeping your main/motherboard, every place you see free pins or connectors there will be a tiny white text next to it on the circuitboard. Fan connector should be between 2 and 4 pins, and be labeled "CASE FAN 1/2" or similar.
Secondly secure the fan itself using either metal screws or anti vibration rubber screws, and you can mount it anywhere it fits / where the power cable allows it to go.
Bare in mind the direction of the airflow when positioning the fan, note that it is generally better to have more fans sucking air into the case than blowing out, creating a higher pressure inside the case and thus preventing dust from getting sucked in & clogging small openings like unused USB ports and most of the media ports on PC back side.
NTLDR system will not boot
To repair missing NTLDR or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Oct 25, 2012 | Gateway 702GE PC Desktop
I turn on my tower and the fans move and the disk try clicks like it wants to spin then i turn the monitor on and it turns green them orange right away and says entering power save mode waht do i do
1) Unplug the computer from power.
2) Press the Power On button in, and hold it in for a count of 10 seconds.
(Count)
Let go of the Power On button.
Do this same procedure two more times. (Or until the Power On LED does not light up anymore)
3) Plug the computer into power. WAIT 1 minute, turn the computer on.
The fans should spin at high speed for a few seconds, then settle down.
Let's see if the computer boots.
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Feb 26, 2012 | Gateway 702GE PC Desktop
Usb boot disk no boot
Change it if you have the warranty as it requires warranty. If you do not have the same, then you may call me at +1 224 636 8057 (10AM EST- 6PM EST).
Feb 23, 2012 | Gateway 702GE PC Desktop
Need gateway users manual for 702ge
http://support.gateway.com/product/default.aspx?modelId=3062
User guide, drivers and full supported files & specifications. Click link above.
Dec 28, 2011 | Gateway 702GE PC Desktop
I want to wipe hard drive and reinstall recovery disc
Insert recovery disk and press any key when prompted on rebooting the fresh install/recovery will give option to format hard-drive
Removing the need to buy any additional software.
Aug 18, 2010 | Gateway 702GE PC Desktop
GATEWAY 702GE FAN RUNS ALOT
So they should al the time.
Mar 30, 2010 | Gateway 702GE PC Desktop
Gateway 702GE desktop When i push the front botton to start it up,the fans start to turn and then stops with no operation. The small green led on the motherboard stays lit and green and the front start...
try removing all the cards from the expansion slots and remove the ram sticks. disconnect the drive cables from the board but dont touch the cpu or power connectors. Now hit the button. If nothing changes, probable board fault. If it now boots up and starts beeping ( which it will when no ram sticks installed) shut it down and reinstall each drive connector, ram stick and card one at a time booting between each item. when the faulty item is connected, the board will stop booting and you can replace that item. Many things can also cause this. Bad connections to ram sticks and video cards, damaged usb port connections, failed cpu's, failed psu's etc.. You may still have to take the machine to a professional repairer to have the problem diagnosed.
Nov 02, 2009 | Gateway 702GE PC Desktop
MY GATEWAY 702GE DESKTOP TURNS ON BUT NOTHING HAPPENS. THE MONITOR WILL NOT TURN ON AND THERE ARE NO BEEPS.
First open cpu cabinet.
Refix yopur ram memory.
Then pull cmos cell from motherbord for 10 minutes so all settings of motherbord are defaults.
Then check .
If still face problem then remove all PCI cards from PCI slot.
Pull motherbord from cabient then check in outside of cabinet some times motherbord is grounding with cabinet.
Also pull processor and its fan then clean dust from all parts.
Also when you power up the computer press F8 key then go to diaply proeprty and change screeen resolution to 1024*768 .
Let me know if you need more assistanse.
Thanks.
Sep 02, 2009 | Gateway 702GE PC Desktop
Gateway 702GE PC Desktop Logo
142 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
