Question about Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator
Freezer is getting warmer, food is thawing, I turned the knob to make it cooler or so I thought, which way am I turning it... down to A or up to E?
    President:
  • 1,902 Answers
E is the coldest setting a is the warmest setting
Posted on May 27, 2010
Frigidaire upright FFU17f9gw3 temperture light is on and food is starting to thaw. I put alot of freezer jam in freezer yesterday
If the control is "ON" and the compressor is not running, you will need a start relay... Make sure you didn't accidentally turn it off by pushing food against the control knob!
Jun 06, 2016 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Freezer temp is below zero it is minus 2.00 will not adjust.
Negative 2 degrees is a good temperature for freezers, but if you want it warmer, raise the thermostat up (warmer temp) In the refrigerator section, & open damper (or set the adjuster knob in the back of the freezer to warmer). If the motor is making a loud noise, it may be hitting ice built up from the evaporator...thaw out.
Feb 28, 2015 | Refrigerators
GE profile side by side fridge freezing and thawing randomly
Defrost entire unit, put food in coolers with ice and unplug. Wait 24 hours with doors open. Any clogs in freon lines should be gone, plug unit back in and see how it works.
Jan 24, 2014 | GE GSS22SGM Side by Side Refrigerator
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Freezer is working, crispers are cool, fridge is not...55 degrees even at the highest cool temp.
Typically the fridge gets its cool air from the freezer via a vent. There is likely something blocking that vent like ice. Move your food to a cooler and turn off the fridge long enough for the ice to thaw (12-24 hours).
If this does not resolve the problem then dismantling of the vents for cleaning will be required.
Mar 03, 2011 | Kenmore 65232
Freezer is not cooling and food has all thawed.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 11, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Whirlpoolpool side by side
The pattern of frost buildup would indicate to me that the freezer door may not be fully closing due to a product on the door or shelve. Frost only on the back wall would indicate a defrost system problem. Frost like snow on product packages indicates air leaking into the freezer in some way.
Nov 11, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Sears Kenmore ColdSpot Frostfree Frosting up/Not working
You have a defrost problem. You need to determine which one of the parts is faulty. The defrost timer on that model should be behind the kick plate in the center front underneath. If you turn the little knob by hand you will hear a load click when it gets to the defrost point and the unit should shut off. Check in the bottom of the freezer to listen for water sizzleing or for water running down. If it is the timer is not advancing and needs replaced. If not you will have to take the back off the inside of the freezer to see if it is the heater or the defrost thermostat. Unhook power before taking panel off or replacing any parts.
Apr 24, 2008 | Refrigerators
Soda can busted in frost free freezer....need tips on how to clean frozen soda up
defrost freezer by turning off fridge. open freezer door, use a hair dryer on freezer compartment to thaw it out,(first remove all good frozen food to a cooler), then simply wipe up the mess. turn fridge back on and reinstall frozen food from cooler.(
Apr 02, 2008 | Refrigerators
Hotpoint HSS25IFMCC / HSS25IFMWW Side by Side Refrigerator Logo
125 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
