Question about Poulan Pro Chain Saw 46cc 20"
I have a Poulan 2050 is there a setting for the the spark plug?
    Brigadier General:
  • 4,088 Answers
Use 0.020" for the plug gap. If the spark is weak looking, check the ignition module to flywheel magnets gap using a thin business card for a gauge--turn the flywheel magnets under the module, insert the gauge, loosen the module screws to allow the module to clamp to the magnets, the re-tighten the screws. Rotate the flywheel to remove the gauge, then make one complete revolution of the wheel while checking the gap--it should not close up any more than originally set. Recheck for blue, snappy spark. Hope this helps!
Posted on May 27, 2010
Poulan chain saw 2050 2.0CL
The Poulan Chainsaw 2050 is a 36cc model with a 14" bar and chain.
Sep 02, 2014 | Poulan Garden
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the spark plug gap for weedeater bv 1850
You shouldn't need to set the gap on plugs when you buy them for handheld equipment. It should be close enough straight from the factory. You can find replacement spark plugs at PartsBuggy.com.
Oct 12, 2011 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I need to know how to adjust carb on a Poulan chainsaw Model number 2050 Preditor
set both jets out 1 1/2 turns and then start it up and fine tune it from there. This will start you out right close to excellent. hope this helps you
Nov 02, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Require high and low carb settings for Poulan 2050 with WT 324 carb. It has no primer, so have bypassed primer and run lines direct. Has heaps of spark but will not fire.
You will find that saws of recent production allow very little if any adjustment for the consumer. The carb will either have limiters which allow you less than one turn of adjustment or they require a special tool to make the adjustment. You will need to take it to a dealer to have these adjustments made. This is your government in action protecting you from that evil pollution your chainsaw spews out.
If you are able to adjust, then gently seat each screw and open 1 full turn. This should allow the unitto start and you can adjust from there. If it will not start you probablu need carb repair or replacement or you have other problems.
May 09, 2009 | Poulan Garden
I need an operating manual for the poulan pioneer 2050 chain saw please
Go to Poulanpro.com and on the right side of site type in model 2050 appaarantly there might be a type number associated with this but I looked at the number 5 and viewed a manual for this saw. It is 18 pages long. Good luck and if I have helped would you please rate this information accordingly. Thank you
Apr 19, 2009 | Poulan Garden
I have a poulan 2050 won't stay running
Hi, are you pumping the primer, till it's full, before starting?
Mar 23, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan Pro Chain Saw 46cc 20" Logo
249 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
