Question about Nikon D50 Digital Camera
My Nikon D50 recently started acting up, does not seem to want to take a picture. The camera is less than 3 years old. I love my Nikon and would be lost without it! Please help!
    President:
  • 1,902 Answers
Have you got more than one lens?
If so, I'd see if the problem is present with a different lens.
It could be a connection problem. Try cleaning your lens contacts (on the camera mount and on the lens) to make sure it's not just a bit of oxidation on the contacts causing a bad connection. A t-shirt with a touch of alcohol would probably do it.
I'd do the same thing with the battery contacts (and try a different battery if you have one, in case the battery has a problem).
Have you got another memory card? If so, I'd try a different one to make sure it's not shorting out the camera somewhere. I'd make sure to format it via the camera menus for format, too.
Posted on May 27, 2010
Hi - I have a Nikon D50 and am using a Panasonic 1GB memory card -- that I have used for several years. Just recently the carmera only allows 12 pictures on this memory card & I'm not sure what is...
Thast's a bit odd, Elise.
A couple of things to check:
1. Is the lock switch in the fully UP position? It is a little slide switch on the side opposite the cut-off corner. Slide it right down then back up again .
2. Does the card have old images, music or other data stored on it? It will hold up to 400 5mb images but it does, like all memory cards, have finite capacity.
3. Have you tried formatting the card in camera?
Aug 06, 2011 | Nikon D50 Digital Camera
Nikon d50 monitor does not work during photo shooting, must use view finder
This is completely normal. The monitor is used for setting menu items, displaying shooting info, and reviewing images. Like SLR have functioned for over fifty years, you take pictures by composing and framing through the viewfinder. Only the most recent dSLRs have the Live View capability which allows you to use the monitor like a point&shoot camera.
Apr 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon d50 black shadow on bottom quarter of picture
this sounds like its 1 of 3 things
1 dirt or dust in camera or lens
2 dirt on sensor
3 sensor is cracked
try giving it a good blow out with air can,,, softly though!
Oct 25, 2009 | Nikon D50 Digital Camera
D50 cannot use a 4gb card??? I use 1gb, 2 gb and no issues, now bought a 4gb card and get a CHA indicator on camera and will not shoot pictures. Can this camera be programed to accept a 4gb or larger...
No, the D50 will not (as you've discovered) accept an SDHC memory card (anything bigger than 2gb is SDHC). I haven't found a firmware upgrade for the D50 to rectify this issue, either. I own a D50 also, and love it, but bigger cards would be nice.
Jul 09, 2009 | Nikon D50 Digital Camera
Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Dec 04, 2007 | Nikon D50 Digital Camera
No picture in the image screen
I suspect that you're looking for a "live view", like in the point & shoot cameras. Most DSLRs (like the Nikon D50) don't have live view. In other words, in order to see the picture you must take it first.
Dec 01, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Lens won't work
I have a D50 as well but never experienced this problem. One thing to check as you already mentioned are the metal connections between the lens and the camera body. Make sure they're clean and shiny. Another thing to try would be switching between AF and MF modes on the lens itself.
Jul 02, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Viewfinder Blank
This suggests the mirror is stuck up in the take position. Remove the Lens and look at what is behind it In the rest mode you should see a mirror. If it is stuck up you would see the sensor window Which do you see. with the lens off - can the camera be switched on? This might just drop the mirror The mirror is surface silvered - do not touch it. If it still up then it is a repair shop/warranty replacement job.
May 07, 2007 | Nikon D50 Digital Camera
Nikon D50 Digital Camera Logo
321 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
