Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan pro 42cc is hard to start ,,, its1 year old an i'm not sure if its worn out from alot of use or if its with the ignition
    Problem Solver:
  • 8 Answers
Throw it out and buy a new one this is a throw away scoiety we live in due to cheap *** chinese **** oh yeah go green
Posted on May 27, 2010
Poulan pro 42 cc 2 cycle chainsaw ignition coils keep burning out
It is not common, but there are so many poor quaility units out there it does not surprise me.
Jan 26, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a poulan pro 4218 it was running great when i put it away last year . went to start it this year put in fresh fuel i have a spark used starting fluid doesnt even try to start what gives?
If there is good fuel in the tank and there is a good spark, there is only two reasons why it will not fire up, the ignition timing is out ( sheared flywheel key ) or there is too little compression ( engine has seized at some time trapping the rings )
Oct 14, 2012 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan Pro 42CC 2 Cycle Chainsaw, 18" It is about 4 months old it will run but the gear that drives the chain is not moving at all when it runs. I can turn it by hand but it is very hard...
It sounds very much like the chainbrake has activated, grab the hang guard and pull it firmly back to the top hadle, it should click when it has loaded, now try again.
Aug 16, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan pro 42cc,18",PPB4218 is very hard to start and runs for a short time and then will not start when hot. It worked well first year, badly this season.Changed spark plug and cleaned fuel filter and...
check basics 1st fuel , air, compression, spark , timming
then secondary compression ie crankcase air tightness
2 strokes need air tight c/case in order to draw in & pump mixture
check your tank breather is working,
has this saw been sitting a while ? if so might pay to rekit carb
check your carby diaphrams are pliable and inlet screen is not blocked and metering needle is set flush with chamber floor,
are hi / lo needles set base settings are 1-1/4 turns out from lightly seated , final hi setting is done while @ full rev and needs to 4 stroke slightly
check ignition spark under load ie while under compression load- could be a weak spark
check timming key
check for a air leak at cylinder / manifold block gasket or carb joint
check barrell bolts are tight everything been = engine should run
cheers
Aug 29, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My Poulan chainsaw is hard to start and will not re-start once it is warm. Any suggestions besides junk it.
Spend $ 40 for a tune up at a local chainsaw seller/mechanic. Most Stihl outlets are very good. It sounds like carburation needs adjustment, but they also do a good visual inspection. Mine get done about every 3 years worth of use. HTH
Lou
Sep 29, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where can I download a free manual for Poulan Pro 42cc chainsaw online
Assuming it's prior to 2007 model year: http://www.poulanpro.com/node5782.aspx User manuals, middle of page: http://www.poulanpro.com/node4041.aspx
Jul 08, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
No spark from spark plug
New Saw? Warranty time
Electronic ignition? Replace entire module. Pinched wire to metal case part for ignition switch. Permanently shorted ignition switch--replace.
Jun 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carburetor overflowing
Gas line from primer bulb to carb may be cracked or broken. Check gas lines for damage. If not that then there maybe an overflow problem in side the carb caused by the float shut off not seating correct or worn "o" ring etc.
May 16, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
269 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
