Question about HP DV9815NR Pavilion Laptop
Dv9815nr Entertainm​ent PC turns on for 5 seconds then turns off
Dv9815nr Entertainm​ent Hp PC turns on for 5 seconds then turns off
My first post... have a Pavilion dv9815nr that I turn on power, the lights come on and the screen lights up but then the laptop turns off in 5 seconds. I do not get any words on the screen. No POST, no BIOS info, nothing. I can't start in safe mode or anything. I have tried different memory, reseated the hard drive, taken out the battery and used on AC power, but still it turns off each time. HP Support thinks its either the motherboard or display (LCD screen), but that's all they can say and naturally its out of warranty. Does anyone have any ideas of first what else to try, second if they are for sure whether its the motherboard or a display issue? I've worked on another HP dv9000 series that had issues with wireless card and but nothing like this. Any ideas? Thanks!
    Scholar:
  • 83 Answers
I have to agree with them if you tested everything else. It could most likely be a mother board issue. It would benefit you to purchase another computer and not try to replace the mother board if its NOT under warranty. That MB will be expensive.
Posted on May 27, 2010
Testimonial: "Thank You I will gave to agree with you"
Dv9815nr cd rom eject button
Yes there is. Open My computer and right click the CD ROM Drive icon and click Eject. This way you can eject your Optical Drive Tray.
Aug 10, 2012 | HP Pavilion dv9815nr Laptop
The problem with the kinect is C000022D
http://support.xbox.com/en-us/pages/kinect/more-topics/errors/red-light-kinect-sensor-5.aspx Red light on the Kinect sensor Last Modified 4/22/2011
Page Content kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive one of the following errors:
A problem has occurred with your Kinect Sensor (C000022D)
A problem has occurred with your Kinect Sensor (C00000C2)
Here's what to do to fix the problem:
update_error.jpg Solution 1: Update your console software
  1. Insert a Kinect game disc.
  2. Start the game from the Xbox Dashboard.
  3. If your console software needs updating, you will see the following message:
    Update Required: An update has been found, to apply this update you must restart your console.
  4. Select Yes, Restart to install the update.
If you still get the same error message, try the next solution.​ ​ ​ Solution 2: Check the cables ​ ​new360cableconnect.jpg
Xbox 360 S console
  1. Turn off the console.
  2. Unplug the sensor from the console, and then plug the sensor cable into the AUX port on the back of the console.
    Important Remove the power/USB adapter cable if your Kinect sensor came with one.
  3. Turn on the console.
Original Xbox 360 console
  2. Make sure the power cord is plugged into a working electrical outlet.
  3. Make sure the USB connector is plugged into the back of the console.
  4. The light located near the middle of the split cable should be green.
    No green light? Try plugging the cable into another outlet to make sure that the cable is working properly. If you still do not see a green light, your cable might need to be replaced. Contact
    Xbox Support.
  5. Turn on the console.
If these solutions do not solve the problem, please contact Xbox Support
Jul 19, 2011 | Video Game Consoles & Games
XBox Kinect says insufficient power I've tried unplugging and plugging into a single outlet but same problem. What can i try next?
Red light on the Kinect sensor Last Modified 16/05/2011
kinectred_300px.gif If the light on your Kinect sensor is red, the sensor might not be connected properly or your console software might need updating. You might also receive the following error:
The Kinect Sensor has insufficient power (C0051202)
If you still get the same error message, try the next solution.? ? ? Solution 2: Check the cables ? ?new360cableconnect.jpg
Xbox 360 S console
    No green light? Try plugging the cable into another outlet to make sure the cable is working properly. If you still do not see a green light, your cable needs to be replaced. Contact Xbox Support.
If these solutions do not solve the problem, the sensor needs to be repaired. To start the online repair process, go to myservice.xbox.com.
Jul 04, 2011 | Video Game Consoles & Games
Don't know how to set the clock on the 9887 in-dash reviever
From the online manual: http://support.alpine-usa.com/products/documents/OM_CDA-9887.PDF
1: Press and hold Func./Setup for 2 seconds 2: Turn the rotary encoder to select General and then press play/pause/ENT 3: Turn the rotary encoder to select Clock Adjust and then press play/pause/ENT 4: Turn the Rotary Encoder to set year 5: Press play/pause/ENT 6: Repeat steps 4 & % to set month/day/hour and minute
Mar 05, 2011 | Alpine Car Audio & Video
Driver hp1010 printer windows 98
Hi afik33.
You need to run the imf16.drv it is located in the folder
English-->Drivers-->win9x_ME-->HB.
If you have an option to browse, browse to this file and open it. The installation should proceed without any problems.
Else you will have to download the latest drivers from
http://h20000.www2.hp.com/bizsupport/TechSupport/D?riverDownload.jsp?pnameOID=306507&locale=en_US&ta...?=English%20(US)&refresh=true&prodTypeId=18972&pro?dSeriesId=306505&swEnvOID=20
Hope this helps!
Dec 20, 2010 | Office Equipment & Supplies
My HP Pavilion dv9815nr Entertainment Notebook PC turned off while I was using it and it wont turn on again.
Hello. I can assist you. Begin by unplugging the pc and then remove the battery. leave it that way for two full minutes as it resets. next reinstall the battery and turn it back on.
Dec 02, 2009 | Health & Beauty
I have an integrated web cam which has quit working,
dear danese, try to update you webcam driver, go to my computer properties, open the hardware tab, click on device manager, push the button on 'Scan for hardware changes'.. wait until you see the yellow circle with big black question mark. right click on it, on context menu choose update driver, (Please note that you have to connect to internet to solve this!). The web should automatically download the driver you need. save it and keep in your favorite folder for your future reference! Try now!
Feb 26, 2009 | HP DV9815NR Pavilion Laptop
Cannot view dvd made from sony handycam
    • hi sir,
    • here is the link to download codec software
    • www.amazon.com/​tag/​camcorder/​forum?​_encoding=​UTF8&​amp;​cdForum=​FxB43NWTLP4H3B&​amp;​cdThread
      THANK,YOU don't forget to rate it..
Sep 09, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
HP DV9815NR Pavilion Laptop Logo
337 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
