Question about Flotec 1/4 Horsepower Sink Pump System
Flotec 1/4 Horsepower Sink Pump System slow to drain. Seems clogged on the sink side of the pump. Can I use Drano or clorox or will that damage the rubber and plastic parts int he pump?
  • 25 Answers
Hi, draino and all those sorts of products only make it worse they will help the blockage solidify best way is to run hot water through the system even if it is boiling water from the kettle and a little bit of a pump with a plunger should do the trick
Posted on Jul 12, 2010
How do I check the fuse on my flotec intellipump
Please review the below web page, it is a troubleshooting guide for your pump. I did not see anything on an internal fuse on your particular pump.
http://www.flotecpump.com/ResidentialPage_resource_ts_utility.aspx
Oct 02, 2012 | Flotec 1/4 Horsepower Sink Pump System
The pump just started running continously. As soon as the pump "cycles" you can hear water running back into the pump. It is an under sink model and the sink is not running.
These units have a "check" valve on the discharge pipe which is a one way flow valve. If debris or sludge get caught in the check valve it gets held open allowing water to backflow. Remove and clean or replace the check valve.
Jun 17, 2011 | Flotec 1/4 Horsepower Sink Pump System
I have a Flotec Intellipump 1/4 Horsepower. I used it to drain a pool and it did just that, but when I checked on it the next morning it was barely running and would not pump water. If feel like it has...
Most pool water from the season before usually contain a lot of sediment, leaves and things like that. These pumps were not designed for continuous use, like draining a pool. Either it has a bunch of junk in it, or the motor just gave up.
Apr 20, 2011 | Flotec 1/4 Horsepower Sink Pump System
Pump will not shut off
Either the float has gone bad or the float is stuck...
give it a kick or a slap and see if that dislodges the float...
If the pump continues to run, open it up and make sure the float has dropped...if it has then the float will need to be replaced...
heatman101
Aug 26, 2010 | Flotec 1/4 Horsepower Sink Pump System
Pump quite working
Start by checking float switch
Jan 09, 2010 | Flotec 1/4 Horsepower Sink Pump System
Pump not kick in
the float has a mercury switch and that is what will make it turn on and off.  this ball sounds like it is not working correctly.  you will have to replace it.  just the ball
Jun 22, 2009 | Flotec 1/4 Horsepower Sink Pump System
How to clean a sink flotec pump
It sounds like the float is stuck. Try pulling the wires coming out of the tank(shake them a little) and see if that will free the float and shut the pump off
Kurt
Apr 04, 2009 | Flotec 1/4 Horsepower Sink Pump System
Flotec 1/4 Horsepower Sink Pump System Logo
241 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
