Question about GE 30 in. JGP326 Gas Cooktop
I need to replace the vent knobs for my GE cook top. Any one know where I can go?
  • GE Master
  • 43,501 Answers
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Aug 18, 2010
Are replacement decals available for the heat settings around the stove knobs?
I Just called GE about this problem, wanna know their answer???
Replace the whole stainless stell cook top piece for $325 ! ! !
Customer Service, at its finest.
This is obviously a GE problem , i live in a neighborhood of recently constructed homes, all of which have the same GE appliances, and all my neighbors are having the same issues.
Gee, thanks GE
Aug 14, 2010 | GE 30 in.JGP330 Gas Cooktop
How do you remove the cook top on a GE profile model number JSP47SOH2SS
take off the knobs, unscrew the plastic underneath the knobs, take off the plastic cover. unscrew the four metal screws holding the the display panel on. remove the 5 silver screws across the top inside of the plastic cover front and the 2 black ones on the lower left and right sides. remove the to stainless steal stews on the sides of the stove towards the rear top. these should allow you to remove the cover once you unplug the two cables going into the burners.
Feb 26, 2010 | GE Cooktops
Hi I have a kitchen aid cook top and need to replace the gas knobs part #KIP5692-3182567 Can you direct me on how to purchase four knobs. Thanks Frank
hi frank
goto appliancepartspros.com
or call 1-877-477-7278
your looking for part number
AP3140295
thay run around 10.00 bucks a pop
hope this helps
Oct 16, 2009 | GE JGP930SEDSS Gas Cooktop
Loud buzzing noise on GE cook top after cleaning
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
tnx gerbee
Sep 11, 2009 | GE 36 in. JGP628 Gas Cooktop
Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Aug 30, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Spark igniters continue to spark:
let it all dry out
thumbs up
Aug 17, 2009 | Cooktops
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Countertop (JGP 3336) control knob does not turn
ouch, sounds as ifthe valve has frozen up, replacing hte valve would be the solution
Mar 17, 2009 | GE 30 in. JGP326 Gas Cooktop
SGM464EM cook top valve rplacement
you have to go in from the top ,,, take off burner, knobs and the screws holding top and raise to get to valves / larry
Dec 11, 2008 | Dacor Preference SGM466 Gas Cooktop
GE Profile JP350 cooktop stopped working
OK, i think the problem took care of itself. definitely got water down in the infinite switch for the lower right burner. let it dry 12 hours and reset the breaker, now works fine. but, i know if i do that again, or if it happens randomly, i will have to replace the switch and seals (available at repairclinic.com)
to do that, you have to remove the cooktop (screwed down by a strap in the back to the back wall of the cabinet) remove the sheetmetal to access the switches and replace. just keep the wiring straight, and ALWAYS replace the seals, they leak over time.
Nov 09, 2008 | GE 30 in. Profile JP350 Electric Cooktop
GE 30 in. JGP326 Gas Cooktop Logo
102 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
