Question about Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592
Where is the button to turn the housing? Where is the button?
  • Hayward Master
  • 1,383 Answers
For power ,if its got one its on the bottom of the plastic cover of back of the motor
if'n i was any help vote .. jay
Posted on May 29, 2010
  • franksmail Apr 01, 2011
    The button to turn the housing is located on the right side of the motor (looking from the rear toward the front). Part of the beveled plastic collar on the actual pump. It is not a simple push of the button with your finger. I had to use a small screwdriver to pry it down "gently" it does not take much, just a bit more than thumb pressure.
The button for the oven won't turn the stove on
go to an appliance parts house and get a new button to replace the one that is defective. Unplug the stove and take the button out by removing screws and wires and take it with you to the parts house. Let them know brand and model number of stove they can help.
Dec 10, 2011 | Kenmore Kitchen Ranges
Tip
Removing Whole House Filters
Frequently whole house filters can be very difficult to remove. The canisters become almost impossible to loosen, even after pressing the pressure relief valve and using a housing wrench. The most common reasons for this are the housing was put back on with the housing wrench, debris in the housing threads and a bad pressure relief valve.
http://i.fixya.neth2oservices.jpg
How to remove a stuck filter housing.
1. Turn off the incoming water.
2. By-Pass the Softener
3. Go to the nearest cold water faucet, open it and let the water run until pressure drops significantly.
4. Turn the water off at outlet of filter (If housing has shutoff on top off head, turn this off now).
5. Press and hold the pressure relief button to relieve pressure further.
6. Use filter wrench to unscrew housing (If it still won't loosen repeat steps 2-5).
7. After removing, clean housing thoroughly, make sure threads are clean on filter bowl and housing head. Lubricate threads of housing and head with plumbers faucet lube or silicone.
8. Clean and lubricate the O-Ring (replace the O-ring every couple years or if housing leaks after screwing back on). It helps to flip the O-Ring over a couple times per year.
9. Replace the cartridge filter and screw the housing back on.
10. Turn the incoming water on slowly while holding the pressure relief button down until all air is purged.
11. Open outlet and let water run to cold water faucet until all air is purged.
12. Put softener back in service.
IMPORTANT! Only tighten the filter housing by HAND!
NEVER use the housing wrench to tighten the housing.
I hope these tips help you with the angst of removing stubborn filter housings.
RJ
on May 30, 2011 | Culligan Under Sink Water Filter
How do you change a culligan water softener filter
The filter housing will have either a shut off valve before and after the housing or a valve on top of the housing that turns (Black).
Shutoffs before and after.
1. Turn both valves off
2. Push the "red button" on top of filter housing and hold to relieve the pressure off housing.
3. Unscrew housing to the left (lefty loosey, Righty tighty) You should have a housing wrench.
4. Remove filter, clean housing, lubricate the o-ring with silicone lubricant.
5. Replace filter, Screw housing back on (Hand tighten only)
6. Open inlet valve (slightly) while holding down the "red button" to relieve air in housing.
7. Open inlet and outlet valves and you are back in business.
PS if the housing is very difficult to remove.
1. Shut off inlet valve
2. Open the nearest cold water faucet and let it run until no water
3. Shut off outlet and repeat procedure as above
Good Luck, RJ
5.
Sep 29, 2011 | Culligan Sediment Water Filter
How do you change the filter to a culligan water softener
Here are instruction to remove the filter housing. This is from my tips posting. Culligan filter housings are just Pentek/Pentair water filter housings and these tips apply to virtually any filter housing.
h2oservices.jpgl76w9ont156vs3p099e2rqu+8nt56e+fbm9ldnps+cnj57dmpqamzqoj3nqs4doe4cr7sqwf8acoamtivyaikaaaaasuvork5cyii=
RJ
Seat wont lock into position as white buttons wont pop out
We had this same problem and I just fixed it today. What is happening is either the white plastic buttons expand with time (highly unlikely) or the black plastic housings shrink with time (more likely). To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers, and sand down the edges of the white buttons to make them slightly smaller. Here's the process: 1. Behind the white button is a screw. Remove it using a phillips screwdriver. 2. You'll now have a black housing with a white button in it, held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs in turn. 4. You'll now have a black base, a black surround (where the button sits), a spring and a white button. 5. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. 6. Reassemble and repeat for the other side. Good luck, Jesse.
Mar 05, 2011 | Bugaboo Cameleon Stroller
Removing cover from big blue 10 water filtering system
The best way to get it off is as follows.
1. Turn the incoming water off.
2. Open the closest cold water faucet and let it run until pressure is relieved.
3. Close the outlet of pre-filter housing.
4. Push the pressure relief button and hold it down until no more water comes out.
5. Use the filter housing wrench to unscrew housing.
6. If it is still hard to take off repeat steps 2-5.
7. Clean the housing and o-ring, lubricate the threads of housing and head with silicone lube or plumbers faucet lube. Lubricate the o-ring with same.
8. Replace filter
9. Only tighten the by hand NOT with wrench.
10. Turn water back on and hold pressure relief button to bleed off air.
The number one reason for filter housings being so hard to get off is people tightening the filter housing with a wrench when re-installing it.
RJ
Oct 09, 2010 | Culligan Sediment Water Filter
I need instructions for replacing the filter on the heavy duty Sediment water filter.
Turn the water off on inlet and outlet, press and hold RED pressure relief button on top of housing.
Use filter wrench supplied and unscrew to the left. Clean housing out and replace filter. Only tighten housing by hand. It helps to press the RED relief button again after you turn the water back on to bleed off any air in filter housing before you turn the outlet back on.
RJ
Sep 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Where is the button to turn the discharge from vertical to horizontal? The manual states to "simply push the positioning button and rotate" - can't seem to locate the button!
Press the positioning button located on pump housing and rotate discharge port to desired position.
Note: the Discharge port will only rotate 1/4 turn.
Jun 02, 2010 | Hayward 1hp Power Flo Matrix Above Ground...
How do I change the filer in my Culligan unit?
Turn the water off IN & OUT, (If this is a Culligan pre-filter it may have the shutoff valve on top), Press the red pressure relief button and hold it down for several seconds. Use the wrench provide and unscrew housing. Clean out the housing, lubricate the o-ring with silicone lube, replace filter and housing. Only tighten the housing by hand. Turn incoming water back on. It helps to hold the pressure relief button down after turning water back on to purge the air.
RJ
Apr 11, 2010 | Culligan Sediment Water Filter Heavy Duty
Disable Powersave mode
i have a mju300 with the same housing.when i put the camera in the housing it is on but i turn the screen off.this is the button that is next to the screen and next to the ok button.when i want to use the camera i just turn the screen back on.
hope this helps
adrian
Apr 14, 2008 | Olympus MJU 400 Digital Camera
Hayward 1hp Power Flo Matrix Above Ground Pool Pump # Sp1592 Logo
177 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
