Question about Kenwood KDC-MP228 CD Player
The word protect comes out on my radio and i dont' have a manual for it
  • 1,305 Answers
"protect" displays when there is a wiring fault. Check all connections at the deck to the wiring harness and then check where all the speakers and amp are connected.
"Protect" usually indicates a short or loose ground. So make sure all your connections are snug and not shorting out or coming loose.
Posted on May 27, 2010
How do I hook it up the amp comes on but u dont here anything on speakers
Pretty open question so lets start with the basics....
1.) Check to ensure your amp is coming on.
2.) Ensure your amp is not going into protect mode.
3.) Double check your wiring is correct (RCA's, REM, GROUND, B+, Speakers)
4.) Ensure your settings on the radio and amp (amp gain is turned up) itself is correct.
These are the simple 4 that should point you in the right direction
Sep 14, 2014 | Kenwood Car Audio & Video
RADIO CODE INSTRUCTIONS FOR A 2007 MAZDA TRIBUTE
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Mazda service centre and get them to enter this code for you.
Feb 05, 2013 | 2007 Mazda Tribute
Keycode
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Ford service centre and get them to enter this code for you.
Jan 19, 2013 | Car Audio & Video
I dont know my serial number but need my radio code as battery went flat any ideas how i can get it free xx
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Jan 08, 2013 | Car Audio & Video
Audi tt quattro 1.8 2004 - radio says safe , what do i do now . i have no pin code
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Audi service centre and get them to enter this code for you.
Oct 24, 2012 | Frontier 2000 00 W/bose Replace Radio...
What is the radio pin for a nissan primastar van ?
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your Nissan servicecentre and get them to enter this code for you.
Mar 24, 2012 | Car Audio & Video
I have a galaxy 88 cb radio that smoke came out from the back side, i dont know if the finals are burnt or bad? how do i find out?
Take the cover off,and look at the inside for any burnt parts. It has a protection diode, a lot of times this will burn protecting other parts from damage,look where the red (hot) wire goes in the radio, there is a diode coming off there, is it burnt, to check the finals you will need a ohm meter,check the circuit board for burnt trace,s....You will need a ohm meter to check the finals, they are mounted on the rail....hope this helps....
Mar 16, 2010 | Galaxy Radios DX- 88HL Base CB Radio
I really need ur hlp badley
If the protection light is lit, the amplifier probably has shorted output transistors. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect mode - Troubleshooting
Nov 05, 2008 | Car Audio & Video
Radio shuts off at volume of 16 or more
Maybe a protection component cutting in.
If you have speakers that are too powerful for the radio it may shut down to protect the amplifier from overdriving the speakers. That produces too much heat in the amp chips/transistors and they either have a overload cut out protection circuit or they burn out.
Even if the speakers are the stock fitted ones the wattage could be bigger than the amp in the radio can handle.
There's probably no way of knowing how powerful the speakers in the truck are but you could try the radio with another set.
Max 50 Watts for that radio. If you don't have the manual for it, it's available here:
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/#_
Mar 07, 2008 | Kenwood KDC-319 CD Player
Kenwood KDC-MP228 CD Player Logo
79 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
