Question about RCA HD52W59 HDTV Projection Television
Picture goes on and off and picture has multiple shadows and th colors are all out whack.
  • RCA Master
  • 8,617 Answers
That can usually be solved by installing the repair kit called the ITC222 and ITC222A convergence option missing repair kit from www.tvrepairworld.com which also includes instructions.
Posted on May 27, 2010
MY TH-58PZ800U is giving me a pictures with dark red shadow
YOU MUST USE THE REMOTE THAT CAME WITH YOUR TV AND ADJUST CONTRAST,BRIGHTNESS,COLOR ETC
Oct 09, 2014 | Panasonic Viera TH-58PZ800U
It has double picture. It is like there is a shadow picture also really bright green,blue,red colors.
usually an issue with the color wheel not being calibrated or the backlight reflecting from multiple angles.
Mar 07, 2011 | RCA R52WH73 Projection Television
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
PICTURE HAS BLUE SHADOWS AND YELLOW SHADOWS
This is a problem with the color weel wich is located in the light engine most of the time tiu need to check out the model numbers to check this out
Jan 26, 2010 | Hitachi 60V500 60" Rear Projection...
Panasonic TH-42PX75U Blue Screen
This could be a reception problem of the cable transmission or the cable box if used. Are you using cable or SAT box. Tv goes to blue screen if signal is weak automatically.
Dec 03, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
Multiple tone color on the screen display with shadows
i think it is an internal problem and it usually appears if the cabinet touches your screen.So go to nokia shop and try to solve it
May 05, 2009 | Nokia N70 Cellular Phone
Printing color shadow
did you used a combat able cartridge ? if yes the ink is the problem if no the problem is firmware
Sep 04, 2008 | HP Color LaserJet 2600n Printer
Colors
Here is a couple of ideas, hope they help...Move any big speakers away from set, if there be any close by.
Also you will need to borrow a degaussing coil from someone, get them to explain to you and show you how to degauss a tv with the colors out of purity. Also, you may have a bad degaussing circuit in the tv...but definetly make sure no big magnetic speakers are in the same area or close to your tv. Hope this helps.
Another problem which would require someone knowledgeable of it, is a problem in the convergence circuit...depending on what brand of tv you have and how new it is...this problem causes an outline or color shadows around people and or objects.....the first problem above causes impurity or splotches of color in the video or picture.
Jan 19, 2008 | Toshiba 36A43 36" TV
Mitsubishi WT 46805 ~ Picture gone..... :0(
Good Day, Corri;
It sounds like the TV has a Circuit problem in the convergence circuit. If it comes and goes then the concern can be corrected by re-soldering the 'conv' output IC"s. A semi-minor repair and cost.
Good Luck, big IRISH.
Aug 18, 2006 | Mitsubishi WT-46805 46" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
78 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
