Question about Bosch 23 in. SHU3307UC Built-in Dishwasher
When you turn it on the pump kicks on and it pumps water out of the resivior at the bottom of the washer. It sounds like thats as far as it gets.Does the pump turn on and off buy a timer or is there a float switch?
    Sergeant:
  • 228 Answers
There is a float switch in the base if you tip machine to the left water will trickle out allowing you to reset machine but if it has a leak you will have the problem return until leak found.
Posted on May 27, 2010
Kenmore Elite HE3 - Washer stopped - door locked - did not drain and spin - Getting error message F02
  1. Unplug the washer.
  2. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer.
  3. The drain/filter/pump is right in front.
  4. You can see a diagram of the pump at http://www.repairclinic.com/PartDetail/Drain-Pump/1200164.
  5. First remove as much water from the washer as you can. Place a large towel under the pump - a lot of water will come out when you remove the filter cover cap.
  6. Remove the drain filter cover cap by turning the filter cover cap counterclockwise.
  7. Remove the filter and check the housing and pump impeller vanes for debris (see if you can move the pumps impeller by hand).
  8. Clean the cover cap gasket and the gaskets mating surface.
  9. Replace the filter and close the cover cap firmly.
  10. Run a short wash cycle and check for any leaks at the filter cover cap. If the error comes back, you may need to replace your drain pump.
  11. Replace the kick panel if none are found.
Feb 27, 2011 | Kenmore Washing Machines
2007 Impala Winshield washer pump does not work
Locate the washer reservoir and at the bottom of that is the pump. With a volt meter, unplug the plug in connector and have somebody press the washer in car. There should be around 12 volts at the plug with the motor not running. If the is you can go to the auto parts store and get a new pump. Easy to install but you will probably will lose the contents of reservoir when you take the old one out. So either catch it or be ready to replenish it with new.
If there is no power at the plug check fuse box for bad fuse. If that isn't the problem then the switch is bad, and needs to be replaced.
Hope that helps.
Feb 05, 2010 | 2007 Chevrolet Impala LS Sedan New Cars
Water is leaking from the front of my topload washer it is a whirpool
do a quick visual test , remove front panel , run washer as usual , with a FLASHLIGHT look or leaks, if its coming from the bottom center of tub , then needs to replace the center seal , hope it helps , AJ
Nov 14, 2009 | Computers & Internet
Wind shield washer fluid stopped working 2005 excursion
Pull resivior and see if it gelled up around screen for pump motor.Cheaper washer solvents tend to do this,If so you can clean screen and it should be ok.Note sometimes you can look down in liquid with flashlight and see gell in resivior.
Jun 19, 2009 | 2005 Ford Excursion
1996 Mitsubishi 3000GT windshield washer will not squirt water!?
Recommend remove nozzel and clean,also recommend remove resivior pump and clean screen,may have solvent jelling up.Very comon when using cheaper solvent.note always use an alchohol base solvent in resivior and make sure water jug is clean.
Jun 16, 2009 | 1996 Mitsubishi 3000GT
How far will a washer pump up water?
Yes, it should pump it that far, but you may shorten the life of the motor by doing so.
Thats only adding about 4 foot since it already pumps it about 3 ft to the standard drain hight.
Jan 27, 2009 | Maytag Washing Machines
Bosch Axxis WFL2060UC/01 FD8205 won't spin
hiya
by elecrical sound i take it you mean a buzzing sound, if so it sounds like your pump is jammed. on the front of your machine their will be a plastic kick plate, if you remove this (carefully) you will find the pump filter, this catches all the debris from the water during the wash (coins,bra wires etc). you can remove this by turning it anti clockwise then pulling it out. remove any obstructions whiich may be lurking in there and also check inside the pump housing as things can get stuck behind the pumps fan then refit the filter.
you may need some old rags whilst you carry out this job as there may be water left i the pipes when you remove the filter.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 15, 2008 | Bosch Axxis WFL 2060 Front Load Washer
F02 code
thats long draining time first check the filter on the pump get a shopvac and vacum the drain hose with the door open till you hear you have all the water out of the washer will make different sound if you dont have shop vac get raditor hose clamp from auto parts store clamp hose going up to tub after you remove the two screws from the front bottom kick plate inside you will see the pump and the hose to clamp if you didnt vacum remove the filter by turning the round plastic piece on the front of the pump see if a forgien object is interfearing with the pump or if the impeller blades are broken if they are replace the pump if not and no foreigen found ckeck the drain hosek for blockage if you used clamp dont forget to take it of before replacing kick plate
Dec 29, 2007 | KitchenAid KHWS01PMT Front Load Washer
Kenmore 80 series washer
sounds like the joint coupler is broke from motor to drive simple 5 dollar item and about 1/2 hour labor to replace its a do it your self job easy to replace but heres another problem that i ran into before you got some material stuck in the water pump that could be the whole problem sometimes people pack washer above the tub then it goes into the water pump
i pulled out my girls sock out of the water pump easy fix tip up washer put something under washer so dont rock foward pull off hoses and then water pump look inside if theres something stuck in there use a pair of needle nose pliars to pull out easy then put back together
Dec 03, 2007 | Kenmore 24902 Top Load Washer
Bosch 23 in. SHU3307UC Built-in Dishwasher Logo
118 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
