Question about Big toys Usa Big Linde Forklift
Oil Filters & oil what type to use. Linde AG-H25T
Baumr ag User Manual Needed
http://baumr-ag.com.au/where-buy-baumr-ag
  • There should if available for your model type a maintenance kit neccesary for your model or all the used o-rings and sometimes special tools because there are special buna-n or nbr o-rings used sometimes braun or green colored on some parts and gaskets, seals and rings used and allways if your tool is leaking then replace the impact bold in front of the spindle if you have find the right drawing for your model type
  • The right lubrication is very important in combination of the o-rings because of the heat building release by rotating and hammering and a leaking tool has oft made all o-rings hardenet because of the failed pneumatic working loose of lubrication dried out principal it becomes very dry internal on some places and much to hot .
Sep 05, 2014 | Drills
Complete service on saxon firestorm oil change plugs filters(types)
Buy the service manual is usually the best bet.
Otherwise call a local dealer or a bike workshop, they will usually have a listing of filters etc for most models.
Nov 19, 2013 | 2009 Saxon Firestorm
P1433 on 03 jetta vr6 24 valve bdf engine code new maf??
It probably the oil in the Filter that mosr cold air intake system use such as K & N. These type of filters use oil in the filter & is coating the sensitve parts inside the MAF. I had the same problem with my 2001 F150 & went back to paper filters, cleaned the MAF, and never had the problem again.
May 17, 2012 | 1999 Volkswagen Jetta
How much oil do i put in my 02 426
Hi, here you go:
Oil capacity is the same as the 250.
1.5 ltrs at oil & filter/s change.
700mls to 1ltr without filter change.
This bike has what is called a dry sump. You fill your oil at the filler point that is located in front of the fuel tank on the frame. It uses the front frame tube as a container for the oil & pumps it back & forth to the motor. This bike has two oil filters.A cartridge type one located behind the small round cover held in place with two bolts that is located on the clutch cover.The other filter is a screen attatched to the spiggot which the hose from the frame(front bottom) slides over. Remove the hose(frame front bottom), undo the spiggot that the hose was attatched to,and as you pull it down to remove it you will see the fine wire screen that is attatched to it.
When you remove the oil filler plug(in front of the fuel tank)you'll notice it has a dipstick on it. When you fill the tank the oil level will seem high. Run the bike first(to let the oil circulate) then check the level on the dipstick. It will now be much lower. adjust the level to the correct level & away you go!
I recomend changing the the cartridge oil filter & cleaning the screen every time you change the oil. Use a high quality oil like Motul & change the oil regularly.
Also keep your air filter clean & oiled properly.
Good luck!!
EJ Kudelka
Nov 16, 2010 | 2002 Yamaha YZ 426 F
I need to know info for an oil change. Type of oil, air filter and oil filter.
YOU CAN USE VALVOLINE 10W- 30 I USE FRAM AND PURALATOR OIL FILTERS AND I USE FRAM AIR FILTERS.
Sep 21, 2010 | 1999 Oldsmobile Alero
HOW OFTEN SHOULD THE AIR & CABIN (POLLEN) FILTERS BE CHANGED ON X TYPE 2lt DIESEL ?
These filters should both be replaced at the same time, every 6000 miles or every other oil change. However, the cabin filter almost always fouls up faster than the engine air filter, so maybe every 3000 miles for the cabin.
Nov 24, 2009 | 2002 Jaguar X-Type
Oil capacity for motor on 2001 yz426
Hope htis helps
Regards Andrew Porrelli
Nov 21, 2009 | 2002 Yamaha YZ 426 F
What type of oil is used in electric chiansaw
The oil to use for the chain is called BAR OIL and if there is anything that might be universal, it is BAR OIL. You can use BAR OIL on electric and non electric saws alike. Self sharpening and non-self shaprening chains. Any manufacturer. It is BAR OIL.
Do not use any other kind of oil in your saw. BAR OIL is particularly sticky and hangs on to the chain even while cutting the wood at high speed.
Thank you for posting your question at FixYa.com
Please remember to vote
a
Nov 11, 2009 | Remington 16" Electric Chain Saw
What types of air filter and oil filter do I need for my 2006 Suzuki gsr?
hi mate if you go on ebay and type in gsr600 service kit it will come up with air filters oil filters and oil and its quite cheap
Aug 24, 2009 | 2006 Suzuki GSR 600
Big toys Usa Big Linde Forklift Logo
97 people viewed this question
Top Big toys Usa Toys Experts
ray gallant
Are you a Big toys Usa Toy Expert? Answer questions, earn points and help others
