Question about Oceana 009008022 Drop-In Kitchen Sink- 009-008-XXX in Black Nickel
The sink is not flush.
When we put the sink in it was not flat . it was unlevel on two opposite corners.
  • 43,501 Answers
That is very common...they never seem to get the bottom completely level so it sits pefectly.
Simply spread a big enough bead of your adhesive caulk on the lip of the sink before setting it. then set the sink and level the front which is where you will wee it the most if there is a big caulk gap. Then fill the gap all the way around smoothing the caulk with your wet finger. Cleaning th4e excess off as you go around...Then let the caulk setup for a half day and you will be fine...
heatman101
Posted on May 28, 2010
When letting the water out of the sink, the water backs up and comes up in the shower how to fix this please.
You have a blockage in your sink line take off and clean trap on the sink replace and flush out . if this does not help put drain clear in sink and shower follow what it says in the bottle and see if this clears the block .
Jan 28, 2018 | Home
How to hook up water and ice maker on Refrigerator when the sink is on the opposite side of the room?
Use a thin 6mm policarbonate piping with quick couplings and glue it in the corner of floor and walls where it is least visible and out of hi traffic. Install shut-off taps on both ends to assist in case of leaks.
Oct 21, 2016 | Refrigerators
Screen dim at 100% brightness
That usually tends to be the power source where the screen is plugged into to and how many other electrical devices are sharing the same power circuit.
Like how a sink doesn't get full water pressure if you flush a toilet.
Try unplugging some devices that are on that wall or corner where you have the screen plugged in and test it out.
Aug 21, 2014 | NEC 22" MultiSync Widescreen LCD Monitor -...
How to cut out for a flush fit sink
There should have been a "cutout" templet with the sink. Generally a "Jigsaw" can be used to cut out the pattern after first drilling a hole to give you a starting point for the saw blade. Put masking tape or duct tape around the cutting area first to avoid marring up the counter when making the cut. One can also put duct tape on the bottom of the saw platform which will give added protection in not marking up the counter while making the cut.
Jun 18, 2014 | Blanco Home
Dishwasher door leaks on the left side at the first part of the wash cycle. Seems like it seals itself as it runs and gets hotter. Cannot see any wear or tear on the door seal (2 years old). will replace,...
Hi there... Try the simple things first. Quite often Fridges and dishwashers (with flat front seals) will start to leak if the body of the unit is distorted. This frequently happens if the supporting feet are not adjusted properly when setting up the unit in the first place. After a while the cabinet will begin to 'sink' in one corner which distorts the flatness of the whole front of the frame, allowing leaks. Try cranking up the foot nearest the leaking seal and see if it makes the leak better or worse. If worse, then crank up the opposite foot. Good luck.
Nov 24, 2017 | Whirlpool Dishwashers
Aerator on Delta Kitchen Sink Faucet does not unscrew
check outside perimeter of airaitor,there should be two notches opposite of each other. example, 3 oclock and 9oclock. use a quarter or similar object , lay across two slots and simply unsrew
Dec 06, 2012 | Plumbing
Unlevel ground 3 inces
No, it wont collapse, if you fill it too full it will just overflow
May 23, 2009 | Intex Easy Set Pool 15x36
My new stainless overmount sink will not lay flat on new counter
Probable not warped, more likely the corner tab is bent. If it is just the corner place a rag over the corner, then using a crescent wrench tighten it on the corner using the rag to protect it from scratches and lightly bend it back. Do this incrementally. If it is more then just the tab ( 6" or more from the corner), remove the sink, place it on the floor, (upside down), place a 2x4 under the offending corner and press down on the sink. Again do this in small steps. Just use a straight edge to know when you have moved it enough.
Before you do any of this make sure your counter top is level!
May 14, 2009 | Hand Tools
Kenmore Washer Tub banging on fast spin
there are some springs that help hold the tub even as it spins also make sure that the washer is level check front to back side to side and corner to corner if it is unlevel they will be out of balance in high speed spin
May 07, 2009 | Kenmore 23822 Top Load Washer
Dishwasher filling with water and flooding when not in use
check to see if your dishwasher is level. If it is unlevel the water could run to the front. Hope this helps.
Jun 04, 2008 | Dishwashers
Oceana 009008022  Drop-In Kitchen Sink- 009-008-XXX in Black Nickel Logo
83 people viewed this question
Top Oceana Home Experts
john h
Tom Chichester
Are you an Oceana Home Expert? Answer questions, earn points and help others
