Question about Kodak EASYSHARE M1063 Digital Camera
I accidently left my camera in the car in the heat. Now the LCD screen is black around the edges. Can this be fixed?
  • 3,866 Answers
To answer you main question YES, you need to bring it to a camera shop and have a new lcd ordered for it. As the sun burned in the liquid and thus the screen will need to be replaced.
please be considerate and leave positive feedback and ratings for your free answer today/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 27, 2010
Screen is black, backlighting gone, but camera still works. Is there a solution for fixing?
The display being black can be due to failure of the LCD or the CCD which is the optical sensor of the camera. So to confirm check the older picture to be seen on the display. Confirm this by checking the card on your PC. If the display is not seen, then the LCD can be faulty, fault on the linking cable or the control board.
However if the older images are seen well then the LCD is working correctly and the fault can be failure of the CCD- charge coupled device in the camera. If you have accidently exposed the camera directly to high intensity light / sunlight, then it is possible that it is damaged. Remove the battery and keep the phone aside to reset and try as a last resort. Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Jul 26, 2011 | Panasonic Lumix DMC-FX9 Digital Camera
Black circles on left edge of lcd tv screen
Bad LCD panel. https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=7857212
May 01, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Lcd tv has a black line near edge of screen it feels like a rubber gasket when you push gently on the screen
Samsung always had problems with their front masks buzzing or rattling at certain audio frequencies. What they started doing is putting a rubber or foam "edge" around the inside of the mask to stop the noise. It sounds like yours has started to bulge out. You would have to remove the LCD panel to really access it and get it back where it belongs.
Oct 13, 2009 | Samsung LN32A540 32 in. LCD HDTV
LCD Scree went blank/black
No problem. Discovered that fix by accident when my camera did the same thing. Since the screen was blank, tried arranging camera setting using the camera's AV cable with the TV, and discovered that fixed it. Apparently corrosion builds up on the AV cable plug switch (which also turns the screen off when inserted), and inserting/removing the plug several times can fix it.
Jul 10, 2009 | Canon PowerShot SD10 / IXUS I Digital...
Canon A630 screen black
Turns out my husband must have pressed a button by accident. The bottom left button says "disp" for display. Pressing that fixed the screen!
Jun 24, 2009 | Canon PowerShot A630 Digital Camera
Lcd aquarter is black
Please clean the lens thoroughly with a soft dry cotton cloth. Clean the edges also. Also try after cleaning the LCD screen.
Feb 10, 2009 | Casio Exilim EX-S600 Digital Camera
Dark black spots around the edges of LCD TV
this issue is tape from the edge of the panel falling onto the screen.You will have to remove the cabinet and the panel from the bezel(front cabinet).remove the screws from the lcd outer edge. Take of the tape.Be very carfull of the ribbon cable that goes to the lcd controller and to the lcd screen itself. They break easy. If you do , its over. you will need a new panel. to much money and work. best to leave it alone.I have fixed it several times for people with warrentys. It is just anoying but will not hurt your tv.
Aug 28, 2008 | Memorex MLT3221 32 in. LCD TV
Blank LCD Screen
Does it still take pictures and you can see them by downloading them to a PC? If so, your LCD screen is probably bad and will need to be replaced. I have replaced these before, its not hard to do if you can purchase a replacement screen.
- Jim
Feb 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Casio exilin ex-s500
Hey i found this site that is great on how to change a LCD for the camera
http://digitalcamerarepair.googlepages.com
Oct 09, 2007 | Casio Exilim EX-S500 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
64 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
