Question about Frigidaire FAA068P7A Air Conditioner
Compressor wont come on
Model # FAA07P7A
Turned it on for the first time this season this evening and the compressor wont come on. filter is clean. we checked reset button etc, plug etc. to no avail.
HELP!!
I believe this is 3 years old. We do not want to have to pay a service call that may be more expensive than a new unit!! But we think it should have lasted more than 3 years!!!!
  • 901 Answers
Check thermostat. Compressor relay. Compressor capacitor.
Posted on May 27, 2010
Propane tank top heater wont stay lit
Try replacing the thermocouple , and clean pilot .
Dec 16, 2016 | Heating & Cooling
A/C unit does not blow cold air
Good Morning Friend,
I understand your Frigidaire air conditioner, model# FAA055P7A1, is not blowing cold air. I also see that you have had it in storage and it has not been run for 5 seasons. Please note that the "Cool " circuit has an automatic 3 minute time delayed start if the unit is turned off and on quickly. This prevents overheating of the compressor and possible circuit breaker tripping. The fan will continue to run during this time.
First, make sure you have cleaned the filter by following these instructions:
• Push the vent handle to the Vent Closed position (where applicable).
• Open the front panel.
• Grasp the filter by the center and pull up and out.
• Wash the filter using liquid dishwashing detergent and warm water. Rinse filter thoroughly. Gently shake excess water from the filter. Be sure filter is thoroughly dry before replacing.
• Or, instead of washing you may vacuum the filter clean.
Secondly, make sure the temperature sensing element, located behind the air filter, is not touching a cold coil. If it is straighten it away from the coil.
Lastly, try resetting your air conditioner to a lower temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 08, 2014 | Frigidaire Heating & Cooling
UNIT WILL NOT COOL. FAN AND HUMIDIFIER WORK. THIS IS ONLY THE SECOND SEASON USED AND THE UNIT HAS NEVER BEEN SITTING UP AND NEVER LAID DOWN OR TURNED UP SIDE DOWN. WHAT IS THE PROBLEM?
A portable air conditioner may not cool for several reasons. Check the filter by removing the unit's grill and clean the filter.
Also check for clogs in the evaporator or condenser coils by light vacuuming. Make sure the evaporator isn't frosted over, but if it is, allow it to defrost and normal operation should resume.
Lastly, ensure the ambient temperature is lower than your AC's set temperature, as this can prevent cooling. However, if all of these steps fail to resolve your problem, the compressor may be malfunctioning, and in this case, the compressor needs to be replaced or repaired.
In summary, if the air won't cool, remove the grill and clean the filter. Clean out any clogs in the evaporator or condenser coils by vacuuming them and scrubbing them lightly with an old toothbrush. And since fan is working, you compressor might be defective.
I hope the above information is clear.
Regards.
Jun 24, 2011 | DeLonghi PAC C120 12000 BTU Portable Air...
"clean and reset filter" alert is displayed even
You can reset the "Filter Time" on your projector and it will clear this error out of the system.
1) Clean Filter
2) Turn the power on
3) Hit the Menu button
4) Once the menu appears choose "Options"
5) Choose "Filter Time"
7) While the time is displayed hold the "Reset" button on the remote for 3 seconds
8) The "Reset" menu will pop-up and choose reset.
That should take care of it.
Mar 14, 2011 | ViewSonic PJ501 Multimedia Projector
I have this ac unit, clean filter light on ??
The filter light comes on buy hours of run time, it's just a reminder to check /clean the filter. There should be a filter reset button on the thermostat to rest the hours counter and the light will go off. If the t-stat doesn't have a button for that, it's somthing like push UP & DOWN at the same time. need t-stat model and serial number to get info, If the installers left the manual for it, look in the index under filter or maintenence. if you're not able to locate the manual, let me know and we can go from there.
Sep 14, 2009 | Fedders SFPEB08F2A Air Conditioner
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Window unit not cooling properly, minimal cooling
SOUNDS LIKE ITS LOCKED OUT ON LOW LIMIT OVERLOAD CHARGE THE AC SHOULD START UP WHEN COMPRESSOR GETS AMPLE FREON
May 03, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Frigidaire FAA068P7A Air Conditioner Logo
203 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
