Question about Brother DCP-7020 All-In-One Laser Printer
The unit prints a heavy black coating on paper
The unit prints a heavy, rough looking, irregular, black coating on paper with different toner cartridges. What is the most likely cause of this?
  • 1,110 Answers
This is caused by corona arcing in the drum unit. When you install the toner cartridge into the drum unit there is a blueish colored plastic tab on top of the drum unit that you can slide back and forth to clean part of the corona. Slode this back and forth at least 5 to 10 times. I would try this first and see if the problem goes away. I have seen this many times and about 50% of the time the plastic slide will resolve the issue. If not you can either go ahead and replace your drum unit with a new one or the charge corona assembly will have to be removed and cleaned.
Good Luck and Thank You for using Fixya.
Posted on May 27, 2010
Consistent dots down print
Try to print clean page ,
Print a cleaning page During the printing process, paper, toner, and dust particles can accumulate inside the printer and can cause print quality issues such as toner specks or spatter, smears, streaks, lines or repeating marks. Follow these steps to clean the printer's paper path.
  1. Load copier-grade paper (not bond, heavy, or rough paper).
  2. On the printer's control panel, touch the Menu button.
  3. Touch Configure Device .
  4. Touch Print Quality .
  5. Touch Process Cleaning Page .
A Cleaning message appears on the printer control panel display while the cleaning is taking place. The cleaning process takes a few minutes to complete. Do not turn the printer off until the cleaning process has finished. A page will be printed when the task is complete. Discard the page. You might need to repeat the cleaning process to thoroughly clean the printer. Print a few more pages to see if the problem is resolved.
Mar 20, 2013 | HP LaserJet 5550DN Printer
Black line on right hand side of the pahe
This usually indicates the the Teflon coating on the fuser roller is damaged and will need to be replaced. The fuser is the part at the back of the printer that heats the toner and fuses it to the paper. The heat roller is coated with Teflon so the toner does not stick. If something scratches this coating the toner will stick and come off on the paper in a line where ever it is damaged. Here is a link to an article showing how to check the toner, the guide is for the 2100 printer but the issue is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jan 22, 2013 | HP LaserJet 2420 Printer
Have a black line printing on the bottom of the page. It appears on regular paper and when we put in paper with a footer, it smudges it.
your fuser unit needs an upper fuser roller or just replaced... there is one thing you can do to see if that is what you need... look inside fuser (its the hot part) do you see a black roller? it sould have no silver or lines on it. That roller is coated with tephlon (i dont know how to spell it) if the coating is gone toner will stick to it and cause that problem
Jul 25, 2011 | Konica Minolta Bizhub c203 Copier
Printing in black is not the same shade through out the paper
This is a very common problem with the Samsung CLP 300 and CLX 3160 printers. What happens is that the toner or developer blades become coated with toner. The developer blades meter the amount of toner that the printer uses to make the image on the paper. When the blade become blocked, the image become faint. To fix this problem, you and either replace the imaging unit for about $100 or you can clean the blades yourself. I have posted instructions how to clean them on my Tips section.
Jan 26, 2010 | Samsung CLP 300 Laser Printer
We had a paper jam and I got the paper out but now the fax machine is printing out pages that are smeared with black toner
The fusing unit heat roller is damaged or worn out and it needs to be replaced.The roller has non-sticking teflon coating.When this coating is bad,toner start sticking to it and causing jams and bad copy quality.
Sep 30, 2009 | Brother IntelliFAX 2800 Laser Fax
How to clean HP4100 TN laser printer? I am getting black streaks down side of page. . .ink is smeared.
There are 3 things to be checked. 1: toner cartridge,try replacing it with a new on. 2: Transfer roller w/c underneath the toner cartridgelying on the printer. Removed toner cartridge,you see a roller w/c is foam like outlook,wipe it with clean dry lint free cloth or paper towel. 3: Fuser unit w/c fuse the ink on the paper.It is lacoted at the back of the machine.Remove the bottom rear cover,just by pulling it. Then you will see 2 blue color lever on left & right,turn those levers up to unlock the fuser unit,then pull out the unit. taking a look in the inner part of the unit you will see rollers . Any bad coating or damage on the roller will create smears on the prints.
Jul 14, 2009 | Office Equipment & Supplies
My copy machine will just print a totally black sheet of paper.
Pull out your toner cartridge, push back the drum shutter and see if the drum is coated in toner. If so, it is defective. Replace it and it will be fine.
*please rate me ;)
Mar 21, 2009 | Canon PC-860 Black and White Copier
How can I make my laserjet prints look as dark as my designjet pr
It si not possible because the %darkness of the black ink and the black toner. The first is near 93% black and the toner even at ***** eye looks dark gray less than 90% black.
Jan 12, 2009 | HP DesignJet 4000 InkJet Printer
Ricoh Aficio cl2000
Most of the time when I find this happening on a printer, not just Ricoh's it turns out to be the PCU (photo conductor unit). The color PCU is one unit and the black is a seperate unit. Hope this helps.
Dec 17, 2007 | Ricoh Aficio CL2000 Laser Printer
Brother DCP-7020 All-In-One Laser Printer Logo
97 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
