Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
X 475 runs good then dies wont start till next day
New fuel filler vent in cap clear
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 197 Answers
Just after machine dies set park brake,remove fuel cap,cycle key on/off and see if you can hear the fuel pump in tank.You may need to be very close to tank in order to notice it.If no sound from tank replace pump.The X400 series are known for their fuel pumps crapping out.
Posted on May 29, 2010
Runs good engine lt on code p0455
A loose gas cap or bad gas cap can cause this ,or filling gas tank while it running .or it could be a small leak in the evap system
Apr 21, 2014 | 2003 Jeep Wrangler
Code # PO446
P0446 Nissan - Evaporative System Canister Vent Control Valve Circuit
Possible causes - Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Vent control valve harness is open or shorted
- Vent control valve circuit poor electrical connection
- Faulty vent control valve
Tech notes Before replacing any parts, try re-tighten the gas cap and clearing the code. If the cap or cap seal is damage replaced cap and clear the code.
Apr 12, 2014 | Nissan Pathfinder Cars & Trucks
1997 isuzu rodeo 3.2v6 trouble code p0446
Here is the description for the code. The vent system would need to be checked out to find the actual problem. It should have been fixed under factory warranty.
The P0446 codes triggered when an improper voltage signal is sent to Engine Control Module (ECM) through EVAP canister vent control valve.
Possible causes - -
- Missing Fuel cap
Read more: http://engine-codes.com/p0446_isuzu.html#ixzz2WVj6BK29
Jun 17, 2013 | Isuzu Rodeo Cars & Trucks
Model 345 won't start. New fresh gas/oil mix. Cleaned carb with liberal applications of gumout. Removed diaphragm and inspected carb, cleaned what passages I could identify. Cleaned fuel line. The fuel...
There is a vent in the tank, it is situated on the right hand side of the tank, close to where the fuel hose exits the tank, the early vent looks like a round white pellet, the later vent is a white plug with a nipple on the top, the later vent will just pull out with long nose pliers, the early vent has to be extracted useing a self tapping screw, this of course will destroy the vent.
Jun 07, 2011 | Husqvarna Garden
My Yumbo Dakar 200cc bike dies after riding in 5th gear reving medium-highish for a couple of minutes, it usually just dies after i hit the clutch (coasting), but on long runs @ around 50-60mph in 5th gear...
G'day,
I have a couple of ideas what may help.
First I would think it was starving for fuel.Or maybe an unusual ignition system fault- So how do we find out?
Well-you could try checking the bike for spark immediately after the bike stops.
Remove the spark plug-Re-fit to the cap-place plug resting on metal where you can see it(DO NOT HOLD PLUG-HIGH VOLTAGE)-kick over & check for spark.If theres no spark-try a new plug but if the problem persists then the bike has a faulty ignition(coil,cap,plug,stator.ignition/kill switch,wireing)
I think it is more likely starving for fuel.
A faulty fuel tank filler cap vent or carby vent tube pinched or blocked.
To check the filler cap-ride the bike & when the problem just starts-quickly crack open the fuel tank filler cap to let air in/out. If bike runs ok then the cap is blocked.
To check the carby vents -just look at them & make sure none are blocked or pinched.They usually come from each side of the carby & one from the bottom(usually clear or semi-clear hoses).
I hope that this helps you with your problem.
Regards Andrew Porrelli
May 17, 2011 | 2004 Yumbo Dakar 200
My lawntractor run for about an houer then is dies
Check the vent in the fuel cap. If this is blocked, then the engine will run until a vacuum forms in the tank and flow stops. This will be worse when the tank is full (less air!).
To test, remove cap, fill tank (tie a rag or something over the filler to keep the crud out), and go mow the lawn. If it doesn't die, get a new cap.
Be careful about fuel splashes if you use the machine with no fual cap!
Jul 17, 2010 | Briggs & Stratton Garden
2001 yamaha breeze wont stay running
i had the same issue. it's gonna be a blockage in one of the vent tubes to the carb. check the line to the left of the carb that runs next to the gas tank. if thats fine then check the gas cap line. then if thats all good then check the line that runs below the carb. these are all vent tubes and allow the carb. to refill with fuel
May 19, 2010 | 2001 Yamaha DT 125 R
Porter/Cable BS1525-w generator, starts always on the first pull, runs fine for an hour or more and then it dies out. Starts right away and it runs again for a while before it dies out again. No matter if...
Hello. I'm sure that you've checked your air filter, so check the pinhole vent on the fuel filler cap. Next time it dies, immediately crack the cap and listen for the sucking sound of air rushing into the tank. If you hear this, clean the cap!
Regards, --W/D--
Jul 23, 2009 | Porter Cable 3,500 Watt 6.5 Hp Portable...
1990 olds will start and maybe just die or will
check for a vapor lock losen up the fuel cap next time it does it and see if it starts
Mar 11, 2009 | 1990 Oldsmobile Cutlass Calais
Won't run at three quarters of a tank
air vent in filler cap blocked
Oct 21, 2008 | 1996 Chrysler Cirrus
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
386 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
