Question about Fedders A6R18E7A Air Conditioner
Air conditioner fan comes on ,but will not blow cold air.filter is clean, anything else I could try? It also cycles like there is power surge.
  • 901 Answers
Check thermostat compressor ON relay, Capacitor.
Posted on May 27, 2010
I have a Fedders Window Air conditioner, model A2008F2BG. It was working great until today. Now it comes on but the fan wont blow much air. Any ideas?
I believe that is an older window unit. I don't know how difficult it is to get to the fan, but I would check to see if it can be cleaned, then see if there is any insulation or anything that is blocking air flow. I am assuming the filter is clean?
Aug 01, 2016 | Fedders Heating & Cooling
Bryant plus 90
try replacing the run capacitor
Sep 03, 2013 | Heating & Cooling
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
Unless we set the thermostat very high, like 80 degrees, the heater will blow cold air. When the heat does blow, it will eventually stop blowing heat and the fan will continue to blow cold air.
Check and make sure the filter is clean. This sounds like a restriction in the system. If the unit has central cooling make sure ther indoor evaporator coil is clean at the furance.The unit may be cycling the burners on and off at the high heat limit , fan/limit control. You can also eliminate the thermostst from the furance. Turn power off at the furnace and disconnect the wiring from the thermostat. Jumper the red and white wire together. Turn the furnace back on. The furance should run in the heating mode. Try this and see if the problem is still there.
Jan 25, 2011 | Heating & Cooling
1.5 ton ac. It is getting cold near the outlet but cold air is not blowing out. Instead pieces of ice are sometimes coming out. How to troubleshoot?
Is the fan running? If the fan is running you should check your filter. If it isn't running then you should check the capacitor for the fan and the fan motor. Also make sure the evaporator coil is clean. If all of this is good then get the refrigerant charge checked.
Jun 06, 2010 | Samsung AW0503B Air Conditioner
My Carrier Home AC unit stopped blowing cold air today. I opened it up and cleaned everything and didn't notice anything out of place, any ideas?
This could be complicated to resolve over the internet but I'll give it a try. When you stated that it stoped blowing cold air, did it stop blowing air all together? Also is the outside unit rtunning?
Sep 05, 2009 | Carrier 38CKC042 Air Conditioner
The air conditioner is blowing very cold air
there are a couple of possibilities here. 1) lack of air flow, due to dirty filter, dirty fan blades/vanes, dirty coil, slow blower motor. 2) lack of refrigerant due to leak or starving metering device. The first one you can deal with: statrt by checking the filter; clean it if dirty. Is the air coming out slower than usual? If so the coil, (the piece that gets cold) fan is dirty; clean them. If it is low refrigerant you will need a professional to repair it or buy a new one. Hope this helps
Aug 17, 2009 | Kenmore 75085 Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Fan is not blowing cold air
Sounds like the freon is gone in the system. These small system will lose freon and then you get air and nothing else
Feb 12, 2009 | Coleman Mach 15 Air Conditioner
Fedders A6R18E7A Air Conditioner Logo
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
