Question about Linksys Wireless-N WRT150N Router
Computer will not connect
I have a 1500N router and my computer or ITouch will not connect. I am trying to reset the password because it will not accept...but no luck. I can type in the new passwork but it doesn't save.
    Problem Solver:
  • 17 Answers
I think I have experienced the same problem. ITouch does not have the same wireless security options as the wireless router does. What you need to do is to find what wireless security options the ITouch has and then set the wireless security on the router to an option the ITouch has. The reason it does not save is that it is detecting that there is a problem, it's stupid and thinks it is just the password that is the problem.
Hope that helps. You might get a better answer if you are able to provide better detail as in what wireless security you are using on both devices
Regards
Raph
Posted on May 27, 2010
My wifi is working, but I can't logon from my iTouch. It's asking for m wifi password, but don't think I have one. what do I need to do?
You can check if you have an Password set to the Network.
- Connect your Computer using a Ethernet cable to any of the 4 LAN Slots on the Router.
- Open Internet Browser & in the Address Box Type the numbers: 192.168.2.1 & hit Enter.
- In the Setup Page Towards your Left Corner Under Wireless Click Security
- Leave the Password Field Blank & Click Submit.
> If the Security Mode is Set to WPA/WPA2/
- You will Find a Small Obscure PSK Box with an Check Mark Uncheck the Box.
- You will see your Password in Pre shared Key (PSK) Box.
> If the Security Mode is Set to 64 WEP.
- The 10 Characters in Key 1 Box is your Password
- Try Joining the Network on your Itouch using the Password.
--- If you Still cant Get the Network to connect Try Resetting the Router.
Mar 26, 2011 | Belkin Wireless Router
I am trying to connect my itouch to my wireless router and it won't let me in even when I enter the password.
You probably need to reset your router. I have had to reset mine several times before I could get it to work.
Oct 14, 2009 | Apple iPod touch
Can not connect to the internet with my new itouch. Have tried all the resets. My password (which is correct) does not seem to work. Says unable to join network. The network is working fine with 2 other...
try unsecuring your network for a test run and see if your ipod can connect if it can theres a problem in the security between the ipod and the router if not then its in the ipod try conecting it to the pc and updating the software its running
Sep 20, 2009 | Apple iPod touch
My mom gve me a Wireless-G access point Linksys
I suggest resetting the router to the factory defaults by holding in the reset button located on the back of the router for 30 seconds.
The router will reset to the ip address of 192.168.1.1 and you can log into it using either a blank username and the password admin or using the username admin and the password admin.
Please let us know if the above was helpful and if there is anything more we can do to resolve your issue. Thank you.
Sep 16, 2009 | Linksys Wireless-G Broadband Router
I don't know what the password is for netgaer
I would nt recommend resetting the router.
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router with the Username as admin and password as password (unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the
routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Aug 09, 2009 | NetGear DG834G Router
Can't connect iTouch to Verizon GT704WG wireless router
Actiontech routers should use the username/password combination of admin // password. If those aren't working, you or someone else, may have changed the default username/password of the router. In that case, you either need to figure out what was set or use the little red button on the back of the router to reset the router to factory defaults. Once that's accomplished, you should be able to use the password combo above.
Mar 05, 2009 | Westell Wirespeed VersaLink...
Ipod Touch can't connect to WiFi
MY only solution was reset my i-pod touch, and after reset it's working very well my Wi-Fi.
To reset your i-pod touch just go to settings
you will find reset button.
Alternately, check your router to see if it actually sees the i-pod.
Try re-synching your i-pod.
Also try resetting your router with the i-pod off then after router resets turn i-pod back on. Should find then..
Hope this helps.
Jan 17, 2009 | Zyxel P660HW-D1 Router
Westell 327 modem is listed on itouch; itouch asks for password
lock on the botom of the router it might be locking for the WEP password on the label
Jan 04, 2009 | Westell Wirespeed VersaLink...
Wifi connection & itouch
I finally discovered the problem. I have a Linksys wireless
router, so when I tried to log on with my iTouch, I got the
message "Unable to join network "my network name" when
I typed in my password. One day, after many trys, I tried
typing in the network security key for my router, and Voila,
it worked. For some unknown reason (to me), the iTouch
recognizes the the network security key as the password.
Mar 31, 2008 | Apple iPod touch
Apple ipod itouch connection to wireless internet
It's since the touch doesn't officially support WPA PSK and only supports WPA2. What will work is WEP and although it is less secure very few people will bother cracking your network. If you continue to have problems with your secured connection try putting the hex key instead of the passphrase (you set hello as your password the hex would something like 0X34Hg65) it is usually displayed just beneath the password you set.
Feb 08, 2008 | Apple iPhone Smartphone
Linksys Wireless-N WRT150N Router Logo
138 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
