Question about Bosch Evolution 500 SHE45M06UC Built-in Dishwasher
Not cleaning well. appears food and water not draining during cycle. Is there a way to clear drain?
    Sergeant:
  • 228 Answers
There shouldnt be much food in it to drain?? consult manual for how to access pump for cleaning it is user serviceable.
Posted on May 27, 2010
Water dripping in fridge from below frezer
There is a drain tube that runs from the freezer/ evaporator compartment that allows ice melt water to drain from the defrosting cycle. Often times that drain hole will become clogged with food debris, glass from a broken heating element, paint chips from scaling and mildew, etc. When that drain hole gets clogged the water has no place to go except down into the fresh food compartment. Unplug the ref and remove the food and ice maker and racks. Remove the freezer back panel and look for a drain hole and clean it out. I use a wet/ dry vacuum at first and if the clog is deeper I will use compressed air to blow the line clear. You can also use a water hose with water pressure. Best done outside of the house.
Feb 09, 2014 | Refrigerators
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cycle finishes but water is not draining
Sounds like too much water leftover.
Give me a make and model number of the dishwasher.
Check that the drain hose isn't kinked, and that where the drain connects at the garbage disposal at the sink isn't partially clogged. And, is the garbage disposal clean/clear of food stuff's.
I had a similar thing happen to me a few weeks ago, and it turned out the kitchen sink drain line was clogged.
Dec 16, 2009 | Cars & Trucks
Soap is not disolving. Falls out of holder and stays on door and floor of washer.
Are dishes also not coming clean? Most likely, there is not enough water chruning in the tub to rinse soap out of cup during wash cycle. Sufficient wash action will wash the soap out of the cup and dissolve it in the water within a few seconds of the cup opening.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Dishwashers
Washer will not pump out water.
drain pump restricted with debree or drain pump bad. if you can hear drain pump humming during drain function then clean out and see what happens
Jun 22, 2009 | Washing Machines
Water leaking from dishwasher lg model lds5811ww
The drain line is clean. Have you checked to make sure the the rest of the drain is clear all the way down to the main drain?. Also check the pump to make sure that it is working properly, it might be pumping water in, but it may not be wanting to pump the water out
Feb 11, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Water won't drain out of dishwasher
outflow soloenoid stuck/ blocked, remove and clean/ replace as required
Jan 27, 2009 | GE Dishwashers
My dishwasher leaves crumbs and food particles stuck to everything in the top rack
Usually this problem is due to the fact that the dirty particle filled water isn't fully draining and the unit is trying to rinse the dishes with fouled water thus baking any leftover food particles during the dry cycle.
Make sure that all of the water is draining from the dishwasher after all drain cycles.
Usually poor draining is due to a blockage or partial blockage in the drain line,also the blockage can be at the drain pump itself or where the drain connects to the under sink drain
Dec 20, 2008 | KitchenAid Superba Architect KBCA06XPBS...
I have a whirlpool water softner. After regenerating, the water is still hard and the tank is about half full of water. I have cleaned the venturi.
  1. Check for hose kinks or food plugging drain hose. Start at the drain port exit (there are others, this is just an example)
  2. Check the check valve and drain hose for debris.
  3. Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
  4. Check timer for not letting the dishwasher pause. ( not all dishwashers )
  5. Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
  6. If you have recently installed a new garbage disposal, check knock-out plugat connection.
  7. Check pump impeller for damage.
  8. Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Dec 06, 2008 | Whirlpool Dishwashers
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Bosch Evolution 500 SHE45M06UC Built-in Dishwasher Logo
167 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
