Question about Electrolux ICON Designer E30SO75ESS Oven
F 13 - Electrolux ICON Designer E30SO75ESS Oven
  • 3 Answers
Had the same F13 code and beeping this morning; pulled the main breaker, waited 5 seconds, reset the breaker, and problem gone. Just had to reset the clock.
Posted on Aug 02, 2010
User Manual Blanco Oven BSO 402w
heres a link to free manual site that has Blanco books Results 1 13 of 13
May 29, 2013 | Ovens
Hi, I am thinking about buying a logik lbfanx10 oven but I understand it has to be hard wired. My old oven is simply fitted with a 13amp plug and it just plugs into a socket. As I do not know the power...
The following website installation and user manual indicates a current value of 13-15 Amperes. You may have upgrade the wiring and the plug.
https://www.manualslib.com/manual/935752/Logik-Lbfanw10.html?page=11#manual Specification Model LBFANX10
Rated Voltage 230 - 240 V
Rated Frequency 50 Hz
Power 3200 - 3500 W
Current 13 - 15 A
Top Element 1200 W
Bottom Element 1100 W
Oct 10, 2017 | Ovens
What is the standard plug for stoves newhome el916. Is it the general 13A plug
I can't find an online manual for the model of the appliance you are talking about, so I'm unable to figure out the wattage it draws. Nor do I know where you are in the world and the voltage you are running at, so I can't tell you straight off. But I can tell you how to figure it out very easily:
I imagine that know what your main power supply voltage is (either 240 volt or 110 volt).
You can look at the appliance and there will be a data sticker with the wattage rating on it somewhere (or it will be in the install/Owner manual).
Now you have these 2 bits of information we can do a simple sum:
Watts divided by Volts = Amps
Therefore example calculations look like this:
If you have a 500 watt appliance on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
An appliance with a 750 watt motor on 240 volts: 750/240 = 3.12 so use a 5 amp fuse
A 2KW (2000 watt) appliance like a hot air blower on a 240 volt system: 2000/240 = 8.33 amps so use a 10 amp (or more commonly 13 amp) fuse
A 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
A 1KW (1000 Watt) appliance at 110 volts: 1000/110 = 9.09 amps so use a 10 amp (or more commonly 13 amp) fuse
etc etc etc.....
If the sum comes out below 13 amps, you can use a 13 amp plug. If it doesn't you need to hardwire it into a proper cooker supply.
Jul 29, 2011 | Stoves Ovens
HOW TO WIRE A SINGLE INTEGRATED OVEN? Can it be wired into the mains cooker point?
An integrated oven that has a 13 amp plug can be wired into a cooker point without any concerns since you are wiring it into a feed that is capable of handling a greater power requirement than is needed.
For the avoidance of doubt, the other way around, if you are considering putting a 13 amp plug on a unit that is designed for direct hardwiring into a cooker point, you should think again because it is probably capable of drawing more current than the 13 amp socket could safely handle
Jul 19, 2011 | Ovens
Outside glass on oven door exploded, can't find replacement code, as ID plate in oven unreadable. Model 65-867
I'm presuming that this is a Simpson Nova 65-867
By the look of all the data I can find, this is an Australian appliance. I'm in the UK, and I was presuming that you were in the US, but maybe you're in OZ.
If you are then you can go to
http://www.alliedappliance.com.au/about_allied_appliance.htm
And mail them with a request for help. They advertise loads of spare parts for your oven (but not glass in the listings I have seen). I imagine that they will be able to source what you need.
You can also make enquiries at The Big Warehouse.com, who also stock parts for your oven:
https://spares.bigwarehouse.com.au/contact_us.php?osCsid=3b1cdec4545fb97a677f2646a2b69530
Finally, go directly to Simpson. Contact information as follows:
Simpson appliances are stocked by a wide selection of quality electrical retailers throughout Australia.
To find your nearest outlet, please call our dedicated customer care number:
1300 363 640
For service related questions please call:
13 13 49
For information about spare parts call:
13 13 50
http://www.simpson.com.au/locator/search/retailer/
Worth noting that Simpson are part of the Electrolux group, so you may get help through a local Electrolux agent as well.
Jun 30, 2011 | Ovens
What does f10 mean on stove oven combo
HI,,
F10
Runaway Temperature.
1. (F10 only) Check RTD Sensor Probe & replace if necessary. If oven is overheating, disconnect power. If oven continues to overheat when the power is reapplied, replace EOC. Severe overheating may require the entire oven to be replaced should damage be extensive.
2. (F11, 12 & 13) Disconnect power, wait 30 seconds and reapply power.
3. (F11, 12 & 13) If fault returns upon power-up, replace EOC
TNKS
RABBANEES
Nov 11, 2009 | Kenmore Ovens
Bosch hba34b520
Yes, it is o/k to have a single oven connected to a 13 amp power supply supplied with a 2.5mm cable.
A lot of single ovens already come with a 13 amp plug fitted, so you can plug it straight into a 13 amp socket.
If there is no covenient socket nearby, then you can wire the 2.5mm cable srtaight into the oven terminal block.
I must stress that this only applys to a single oven and not a double one.
Plz rate my solution.
Thanks.
Jan 13, 2009 | Bosch HBL 442 / HBL 446 Electric Single...
Electrolux ICON  Designer E30SO75ESS Oven Logo
218 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
