Question about Maytag M7D24E7A Air Conditioner
The a/c is not cooling, how do I know its not the compressor
  • 901 Answers
If the compressor is running and not cooling, it is a sign of some blockage or gas leak.
If compressor running, remove the front grill, filter screen. Feel the evaporator (cooling ) fins top to bottom or vice versa. If little chillness is noticed faintly it is gas circuit related. Capillary block or gas leak or weak compression of the compressor. Take service help.
Posted on May 27, 2010
Dawlance split ac
My guess is compressor motor overtemp cutout. So why is the motor overheating? Possibles: Needs bearing oil, bad bearings, compressor too much pressure, overfull with freon, mechanical friction, cooling fan not turning.
Suggest set thermostat to demand less cooling, see if compressor stays on longer.
--Gil
May 25, 2014 | Haier 18000 Btu Air Conditioner Heat Pump...
Not cooling
You can ohm the compressor to see if it is shorted but if the compressor is running it cannot be the overload or relay , if not running sometimes you can pull the relay and shake it if you hear any rattling in it it is bad
Apr 01, 2013 | U-Line 1175BEV Beverage Cooler
Refrigator not cooling but freezer is.
Need to unplug and lets find the problem. The compressor cannot take much of the overheating. Find your model number like 213.256489 for example and let me know, I would like to see what condition the start relay and capacitor are in. And check the compressor windings. Let me know Sea Breeze
Aug 19, 2009 | Kenmore 53542 / 53544 Side by Side...
Refridge quit cooling suddenly inboth freezer
That could be a broad range of possibilities. The defrost timer, adaptive defrost board,compressor start relay, compressor start capacitor or a mother board. Would you happen to have the model number so I can narrow down those possibilities? If you pull away from wall remove cover over the compressor and then unplug. Touch the compressor and let me know if cool, warm or too hot to touch. Thanks, Sea Breeze
Aug 19, 2009 | Kenmore Refrigerators
Stopped cooling
Best to unplug the refrigerator now and let compressor cool. The internal overload will be damaged if power remains on and trying to start. We need to test the compressor and start components before you buy anything, Let me know Sea Breeze
Aug 18, 2009 | Frigidaire FRS26R4A Side by Side...
The mini fridge does not cool. This fridge doesnt use any fans so nothing to check there. The compressor seems to be awfully hot (although I dont know if thats normal) you wont born your hand but it would...
Hi, it's possible,your motor overlay relay has switch off motor, if your days are hot, or if room temp get high, that could happened,unplug ref. let motor cool down for about an hour, if compressor is running, but not cooling, it's possible you got a freon leak, normally ref have a condensate line, that passes through, front of door, that usually get rusted and leak,normally we by-pass it, now if there's a leak, you will have to repair leak first, you will have to change filter drier, vacuum and recharge. no you won't be able to buy freon and tap it up, same princple like vehicle a/c, but, different application, could also be an electrical problem, check motor overload, situated on compressor terminal, remove compressor terminal cover, and you will see overload relay, it's round, has one wire connected to compressor terminal and another connected to wiring harness. also, you can check compressor for short circuit, remove 3 wires from compressor terminal, place one tester lead on copper tubing coming from compressor and next tester lead, place on compressor terminal one by one, if you hear a beep (continuity) from any one of those terminals, compressor windings are faulty, replace compressor, or could just be hot summer months, let it cool down, but remember, remove plug from receptacle. or you are victim of low voltage, low voltages are more frequent in summer months, it could damage compressor winding, or compressor overload relay, let it cool down, and retry it. let me know what happened, before you attempt any repairs. and i can tell you what exactly what the problem are. good luck.
Aug 11, 2009 | Sanyo SR-4911M Compact Refrigerator
Cools at start up....then gets warm..compressor is warm.
I would need to know the model of this. However if the condenser fan is Not runing then the problem is that. If it is then it could be the sealed system and you will need a tech to check it out.
Apr 10, 2009 | U-Line 15R Compact Refrigerator
Maytag msd2454gr
The click is not normal. The compressor is not starting and is tripping the overload. There is a chance the start relay on the compressor is shorted, but most likely the compressor will have to be replaced.
Unplug it for several hours until the compressor cools down and then try it again, if it starts up ok when it is cool the compressor is the problem for sure.
If it is less than 5 yrs old the compressor is still covered by warranty and will be replaced free of charge.
Dec 07, 2007 | Maytag MSD2456G Side by Side Refrigerator
Amana side by side compressor not running
Cleaning the fins is always good. Is the fan by the compressor running? It needs to help cool the compressor. The description you mention sounds like the compressor is overheated and tripping the thermal overload on the compressor. See if you can turn if off for a day to let it all return to room temp then see if the compressor kicks on. If it was overheated it should run again for a while before overheating again. Let us know how that works and we can go from there.
Nov 29, 2006 | Amana ASD2326HE Side by Side Refrigerator
Maytag M7D24E7A Air Conditioner Logo
Top Maytag Heating & Cooling Experts
Bill Long
Donni Steen
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
