Question about Dynex Multimedia Keyboard
Laptop top keyboard will not function appropriately unless Dynex separate keyboard is used. I am unable to identify the Dynex device to uninstall. First listed states Std 101/102 Keyboard and the other HID Keyboard Device in the Control Panel listing.
    Genius:
  • 1,189 Answers
Hi, these instructions will help you, first, click on the "Start" button, in the "Start Search Window, Type: keyboard; the "Keyboard's" Properties window will open. You can (Test) to see exactly how your keyboard is responding. if you are still having the same problem, (check the Keyboard Status), try "Updating the Drivers," by clicking on the "Properties" button. Now in the event that neither of these solutions solve the problem, which I hope you shouldn't have to do anymore; try "Uninstalling the Keyboard. To "Uninstall the "keyboard," do the following. Shut-down (turn- off completely), disconnect all the Keyboard Devices that are attached to the computer. Next, turn-on the computer, and go back to the "Keyboard Properties," this time click on the "Change Settings" button, next click on the "Driver" button, and select the "Uninstall" button. Once that is finished, shut-down the computer again. Now you want to "Reconnect" all the devices that were connected before, and "Turn-on" the computer. You will repeat exactly what you did from the start, this will "Reinstall the Keyboard. Restart the computer again after all changes have been made; this will ensure the changes take place properly. "Rating the solution will let me know if it worked, or you may need further assistance, thanks."
Posted on May 27, 2010
Keys not working
Well, the most common cause of a non-functioning keyboard is a driver issue. If the keyboard driver has been updated by normally a third party update application, then the most recent driver must be uninstalled by using the "rollback" feature. To check this, go to "computer management" then "device manager" then find the keyboard, then "right click" on "properties" go to "driver". Check the date which the driver was updated. If was recent, around the time the keyboard ceased to function, then click on "rollback". You may have to use an external keyboard with a USB plug to do this, as of course the laptop keyboard doesn't work.
A second option is to attach an external keyboard and initiate a "system restore". Go back to a date in which you believe was "prior" to the keyboard issue.
A third possibility is a virus. Once again, attach an external keyboard and run all anti-virus programs to include "spybot search and destroy", "Malwarebytes" and your primary anti-virus program.
There is a forth possibility. If the laptop has been opened for any maintenance, and the underside of the keyboard was exposed, any dust, and I do mean "ANY", just one speck, can cause issues. This is not likely or common.
So unless there are some key events which would cause me to go down another path, one of these solutions will work!
Aug 27, 2013 | HEWLETT-PACKARD ProBook 4520s
Nc6000 doesn't boot unless I push on the keyboard
Your graphics chip has a cooler which tends to separate from the motherboard causing a failure on bootup. This can be fixed by adding a spacer to the cooler then reattaching the cooler with the 2 screws which hold it down. This chip and cooler are located directly beneath the keyboard which is why pushing down on the keyboard causes the laptop to work for awhile. Releasing the keyboard is pretty easy since the screws are identified on the underside of the laptop. Remember to add thermal paste when re-applying the spacer and cooler.
Mar 14, 2010 | HP NC6000 Notebook
I have a dynex TV I am trying to connect to my laptop via HDMI. The TV works fine as far as displaying cable but when I try to hook it up to my laptop the screen displays for one second then flashes to...
Make sure that you set your laptop to external display by using the proper F key, located on top of the keyboard. It looks as though there are two computer monitors on it. My Gateway is F4 for example. Press the function key and the proper F key simultaneously. There are a few choices, so you may have to push it more than once. I hope this helps and good luck!
Please remember to vote 937f12f.jpg Thanks.
Oct 31, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Sony laptop cannot use keys on the laptop seems to have frozen
It could be a software or hardware issue.
Check Sony's website for updated keyboard / touchpad drivers.
If that doesn't work, uninstall the keyboard from the device manager and reboot the computer.
If that doesn't work then it's likely a hardware issue.
Jun 13, 2009 | Computers & Internet
My key pad is frozen
If you have an extra usb keyboard available you should be able to use the laptop.
I would suggest going into control panel -- then devices -- check to see if there is an "explanation point" next to the keyboard device.
If not, right click on the keyboard icon and click update driver.
I've also selected "uninstall" for this device and restarted the computer. Many times windows will reload the keyboard driver. The current one may be corrupted.
May 27, 2009 | HP Pavilion TX2000Z Notebook
My Compaq Presario computer will not boot up unless I hook it up to a separate monitor. When I do this it runs perfectly and the laptop screen even comes on. Any ideas?
Sounds like you just need to select the mode your display is in .
You should see a colored "Fn" key on your keyboard which when used in conjunction with the appropriate key will switch from external to laptop monitor.
Apr 21, 2009 | HP Pavilion dv6000z Notebook
Keyboard problem - asus
it seems to me that you have the NumLk activated, deactivate it by pressing Fn + NumLk, hope this works!
Nov 01, 2008 | ASUS Eee 4G Notebook
Mouse trouble
To fix this problem, first uninstall your mouse in your device manager. After this, use the mouse's install CD to reinstall the driver. If you do not have a CD, or it does not require a CD, windows may already have the driver pre loaded and can take care of it. If not, you can goto the mouse manufacturers web site and download the driver from there.
Dec 05, 2007 | Dynex DX-WOM20 Mouse
Dynex Multimedia Keyboard Logo
189 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
