Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
F 10 comes up on display
When f 10 comes up I think the temp keeps rising past what is set
  • 327 Answers
Hello, this is a oven temp sensor failure notice. you will need to check the wires leading from the temp sensor to the control. if the wires are in good condition and , the sensor harness is not welded, replace the temp sensor asap.
Thanks
Posted on May 29, 2010
Frigidaire oven temperature unreliable.
Is this an electric oven? Sound like a bad breaker to me if it is.
Dec 22, 2016 | Frigidaire Ovens
Whirlpool super capacity 465
Seems the thermostat is malfunctioning...thus when baking at 500..thats quite high...it keeps getting hotter past that point to where the oven thinks its in self cleaning mode. Also seems like the problem because when it cools down your allowed to use it again. There is no way to test it with an ohmmeter. Just remove and replace.
Nov 30, 2013 | Ovens
My lincoln impinger pizza oven keeps showing LLL on temp reader after reaching its temperature,then the temperature keeps rising until it shuts off.
This error LLL on the display screen is as a result that the temparature controller is faulty or the the temparature probe is kaput
Apr 29, 2011 | Lincoln 1132000U - Impringer II Express...
Old kenmore built in oven wont unlock
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Apr 09, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
I have a frigidaire stove that heats to 50 degrees hotter than the know setting. Can it be adjusted to read correctly?
There is a calibration method to adjust the oven thermostat plus/minus 35 degrees if it is a digital display. The method varies depending on the model range. This calibration method is used to adjust the thermostat if it is not keeping proper tempature. For example if you are setting the oven to 350 and the actual temp it is keeping is 325 then you could use the calibration method to adjust it plus 25 degrees to correct the temp. Just so you know electric ovens will keep a pretty even temp but gas ovens will vary by 40 or more degrees to keep an "average" temp. For example the burner will come on when the oven is 330 degrees and turn off at 370. 330+370 then divide by 2=350. So a oven thermometer may not show you the temp you set it at in a gas oven but does not mean the oven temp is off.
Jan 14, 2010 | Ovens
Turbochef toaster oven cc temp on warm up only 265 deg ir 465
if your a commerical oven tech then just call 1-800-90turbo are you getting an error code i would probably check the convection circuit first starting with the blower motor and checking if the Windings are ok
Dec 12, 2009 | TurboChef TORNADO Electric Oven
Gaggenau wall oven
hi thanks for the question plus or minus 25 degrees is acceptable the heat will go past the set setting turn off and go below the set setting but the average temp is ok so there is nothing wrong thanks the appliance doc
Sep 27, 2008 | Gaggenau EB388 Electric Single Oven
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
77 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
