Question about Kenmore 72059 Air Conditioner
The fan on my air conditioner sounds like something is impacting the blades. How do I find out where the fan is to look at it myself?
  • Ethan Rogati
    Ethan Rogati May 27, 2010
    It seems to have resolved itself, which leads me to believe that it wasn't a mechanical problem, but something that got into the unit during a strong storm last night.
  • 901 Answers
Switch off power. Pull the chassis carefully 50 to 60%. You will find a motor centrally placed. Rotate by hand and align it suitably.
Check the shaft grub screw for full tight.
Posted on May 27, 2010
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Window / through wall unit made by haier, i can't find a model number. but it's making an awful racket like a blade or something hitting something. also slightly blows out a light fine mist of...
Where the unit drains is clogged it sounds like so your fan blade is hitting the water and scooping some of that water indoor. look where the condensate drains and clean that and it should be fine
Aug 14, 2011 | Haier ESA3125 Wall/Window Air Conditioner
My air conditioner unit outside is making a very loud banging noise. It sounds almost like a small jack hammer. i noticed it this mornin and immediately turned off my system. Any ideas?
Hi!!
Have you taken a look at it???? It sounds to me like the condenser fan blades are bent or something fell in thru the grill that the blades are hitting on. If this is the case, TURN OFF POWER TO UNIT AT BREAKER BOX , remove the screws around the grill or cover
to get to the blades and fix the problem..
Don't forget to rate this post!! Good Luck!!
Jul 11, 2010 | Heating & Cooling
The rear air conditioner makes a clicking sound
My 2004 Ford Makes the same sound with the rear air conditionar if you found how to fix it i would like to knw
Jul 10, 2010 | 2004 Ford Expedition
Just brought home a fedders aep09d2b*b portable air conditioner. bought it used. it worked well there but when I plugged it in at home it is making a lot of fan noise - more noise the higher the fan...
If it was running fine before and you moved it and it's making noise, it sounds like something fell against the fan blades. The reason it sounds worse when you turn it up is that the fan is running fast. Grab a flashlight and check to see what might have fallen.
May 12, 2010 | Fedders A6P09D2B Portable Dual Hose Room...
Makes loud noise while cooling. sounds like fan is hitting something. a/c is 4 years old, in the wall, problem just began July 2009. Lowering fan speed, or energy saver setting do not help.
That's because it probably is.Shut it off.Pull it out.Set it on a table by the outlet or a/c housing.Plug it into the same outlet.Keep fingers away from the blade and visually watch it.
My guess is the fan blade loosened on the shaft and needs to readjusted and tightened.Or the wires need to be moved out of the way of the blade and tie down(not on the fan blade either foo!!!).
Aug 01, 2009 | Frigidaire FAS256N2A Air Conditioner
Loud sound when turning on LG aircondition unit
Is it the outside unit ofr the inside... either way sounds as if the blade is hitting the fan shroud. you should be able to access unit to see exactly where noise is coming from.
Feb 06, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Lg 18000 remote with heater
your fan blade hit something and i think one of the blade got damaged and somehow it is no longer balance and makes a lot of vibrations.
have you read in the instruction manual to remove some kind of a shipping support before running the unit?
im just curious what hit your blade. it could be the shipping support for the compressor.
tnx 4 using fixya,
drcool
Sep 14, 2008 | LG BG8000ER Air Conditioner
Kenmore 72059 Air Conditioner Logo
53 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
John Tripp
John Tripp
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
