Question about Kenmore Elite Oasis 27052 Top Load Washer
Code HC is appearing on the digital display? - Kenmore Elite Oasis 27052 Top Load Washer
  • 15,935 Answers
This HC error code will appear at the end of the wash cycle to indicate that the hot and cold water inlet hoses are switched. If the hoses are not switched it could indicate a problem with the Electronic Control Board. You can try to rest the washer by unplugging or flipping the breaker to the washer fo 2-5 min. Restore power to the washer and try running a short cycle. This will help clear any irregularities that the control board may have encountered.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(())
Posted on Sep 27, 2010
Need to know what HC means on my washing machine Kenmore Elite Oasis. wash did come thru from the bottom
hi there
HC means that the water hoses have been changed or the hot is in the cold and vice versa. put the hot water to the hot on the machine and the cold to cold and this will stop the HC code.
and on another site
The "HC" indicates that the Hot and Cold water supply lines are reversed. Shut the cold and hot water supply valves off and then remove and reverse the hot and cold water fill hoses on the washer and then see if it continues to display "HC".
what HC means on my washing machine Google Search
Aug 07, 2017 | Kenmore Washing Machines
HC-W970. Is there a firmware update?
Your model appears to be HC-WX970????
There does NOT seem to be a firmware update
Verify with correct model number at
Downloads
Apr 04, 2016 | Panasonic Cameras
I need a owner's manual
About 7,710 results (1.05 seconds) Search Results
    [PDF]HC-V10M HC-V11M - Panasonic
    service.us.panasonic.com/OPERMANPDF/HCV10-MUL.PDF
    PanasonicNov 15, 2012 - Owner's Manual. Digital Video Camera. Model No. HC-V10. HC-V10M. HC-V11M ... You have purchased one of the most sophisticated and ...
    Panasonic Product Support - HC-V10K
    shop.panasonic.com > Get Support
    PanasonicOperating Instruction Manual ( Multi ) - HCV10. FAQsFrequently asked questions about your product. What should I do if my product needs service? ... How am I able to turn off the time and date display on my camcorder? ..... LENS (ILC) POINT AND SHOOT DIGITAL CAMCORDERS LENSES ACCESSORIES · HOME HOME ...
    Panasonic HC-V10 Operating Instructions Manual
    www.manualslib.com > ... > Panasonic Manuals > Camcorder > HC-V10
    Basic Operating Instructions Digital Video Camera HC-V10 Model No. Before use, please read these instructions completely. More detailed instructions on the ...
    PANASONIC HC-V10 Operating Instructions Manual
Feb 08, 2016 | Panasonic Hc-v10 Digital Video Camera 70x...
2000 Chevrolet Lumina Unlock radio code
If you have the security code it's easy. The code is something that either you or a previous owner entered. If you don't have the security code a trip to the dealer will be in your future.
Unlocking the Theft-Deterrent Feature After a Power Loss
Enter the code as follows; pause no more than 15 seconds between steps.
  1. Turn ON the ignition. LOC will appear on the display.
  2. Press MN and 000 will appear on the display.
  3. Press MN again to make the last two digits agree with your code.
  4. Press HR to make the first one or two digits agree with your code.
  5. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show SEC, indicating the radio is now operable and secure.
Entering the incorrect code eight times will cause INOP to appear on the display. Wait an hour with the ignition in the ON position before you try again. When you try again, you will have three more chances (eight tries per chance) to enter the correct code before INOP appears.
Deactivating the Theft-Deterrent Feature
  1. Turn the ignition to ACC or ON.
  2. Turn OFF the radio.
  3. Press the 1 and 4 buttons together. Hold them down until SEC shows on the display.
  4. Press MN and 000 will appear on the display.
  5. Press MN again to make the last two digits agree with your code.
  6. Press HR to make the first one or two digits agree with your code.
  7. Press AM-FM after you have confirmed that the code matches the secret code you have written down. The display will show -- -- --, indicating that the radio is no longer secured.
Entering the incorrect code will cause SEC to appear on the display. The radio will remain secured until the correct code is entered.
Dec 27, 2010 | 2000 Chevrolet Lumina
I have lost my radio code for my ford can you help.
Late Four Digit Ford Radio Codes (no SELECT button) ie. Ford 3000 Traffic, 4000RDS, 5000RDS, 6000RDS, 6006E, etc Switch the radio on and the word CODE should appear in the display Repeatedly press button 1 until the correct first digit of the code is displayed.
Repeatedly press button 2 until the correct second digit of the code is displayed.
Repeatedly press button 3 until the correct third digit of the code is displayed.
Repeatedly press button 4 until the correct fourth digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press button 5 to enter. If "LOCK 10" is shown on the display, please contact us for guidance. If the display shows "LOCK 13" code entry will not be possible, and the unit will need to be electronically decoded by a car radio servicing specialist. Early Four Digit Ford Radio Codes (units with SELECT button) ie. Ford 2005, 2006, 2015, etc Switch the radio on and the word CODE should appear in the display. If CODE does not appear immediately, press the SELECT button momentarily, and CODE should then appear on the display. Repeatedly press button 1 until the correct first digit of the code is displayed.
Once the code has been correctly selected on the radio's display, press the "SELECT" button to enter. Three Digit Ford Radio Codes ie. Ford 2000, 2001, 2005, 2007, etc Switch the radio on and the word CODE followed by three dashes should appear in the display. These three dashes should be flashing. Enter the three digit code by repeatedly pressing station presets 1-3 until each digit is correctly displayed, followed by preset 4 to accept the code. The unit should then function normally. If, after switching the radio on, the three dashes do not flash, then 3 or more incorrect code entries have been attempted. If a number 10 appears in the display, then ten incorrect codes have been tried and the unit will need to be decoded by a car radio servicing specialist.
Jan 25, 2010 | Car Audio & Video
I have a 1999 corvette showing trouble codes C1790 H, and B2606 HC can you help identify these codes
c1790 H ride control switch, the "H" indicates it has occurred at some point but is not present now. The H stands for history
b2606 HC is seat rear vertical position sensor failure. This code always appears as a history code. If this condition is current, your seat memory won't function.
Jan 15, 2010 | 1999 Chevrolet Corvette
Malibu 2001 radio locked
hi friend,
Deactivating the Theft-Deterrent Feature Enter the code as follows; pause no more than 15 seconds between steps.
Entering the incorrect code will cause SEC to appear on the display. The radio will remain secured until the correct code is entered. When battery power is removed and later applied to a secured radio, the radio will not turn on and LOC appears on the display. To unlock a secured radio, refer to "Unlocking the Theft-Deterrent Feature After a Power Loss".
hope this helps u
please rate me..............
thank u for using fixya
regards
sivvaranjini
Nov 26, 2009 | 2001 Chevrolet Malibu
What does HC stand for?
According to the Whirlpool "Cabrio" washer installation and maintenance manual, (Cabrio is the Sears Oasis) the HC code will come up when.
“HC” (Cold and Hot hoses switched)
This code will appear at the end of the wash
cycle to indicate that the cold and hot water
inlet hoses are switched. If an error code
does not appear, but you are experiencing
poor washing performance, check to see
whether the inlet hoses are reversed. See
“Connect the Inlet Hoses.”
Sep 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Monitor displays HC at end of cycle
Jun 28, 2009 | Kenmore Washing Machines
Unlock ford car radio. have code.
can you give the number or name of the model
Apr 05, 2008 | Car Audio & Video
Kenmore Elite Oasis 27052 Top Load Washer Logo
299 people viewed this question
Sal De
fordexpert
Robert Rankin
