Question about Roper REX4634KQ Electric Dryer
How do you wire for a 3 prong cord? I just into a house and I was using a four prong cord, but the new house needs a 3 prong. so I bought a 3 prong cord and I just want to make sure I install it correctly. I see the 3 leads black white red on the dryer plus a ground bolt with an extra white wire hanging from it. the new 3 prong cord has all gray wires. What goes whrere? Thanks for your help Eddie
  • Roper Master
  • 43,501 Answers
Here is a tip that will help you with that...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Posted on May 27, 2010
New house has three prong recpticle dryer cord has four prongs. Can I use a three prong cord and strap a wire to the fourth wire on back of dryer? If not got a solution?
If the new house has an existing three-wire outlet, the simplest solution is to install a 3-prong power cord on your dryer. The following link explains the differences between a 3-wire and 4-wire configuraiton:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
So...if you need to install a 3 prong power cord, it should be wired as follows:
RED (HOT) 120VAC to RED
BLACK (HOT) 120VAC to BLACK
WHITE (NEUTRAL) 0 VAC to WHITE - a Ground wire needs to be connected to the Neutral lead at the terminal block and grounded to the dryer cabinet.
The other alternative would require you to install a 4-wire receptacle so you could still use your current power cord. A certified electrician is recommended for this job and may cost you some money. A replacement power cord, on the other hand, usually costs less than $20 and can be found ay any hardware store.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 10, 2010 | Dryers
I moved to a house with a three prong outlet for my Frigidare electric dryer, model number FER341AC0, that has a four prong cord. I bought a new three prong cord but there is no color coding on the dryer...
The three wire goes on the electrical block on the back of your dryer just like the cord is made. If you look at the cord, it's made flat (Most 3 wire cord are made flat, Some are not) The wire in the middle goes in the middle of the block. The two wires to the outside go to the outside of the block. It makes do difference which wire goes on which side as long as the outside wires go to the outside.
Please rate solution
Sep 06, 2009 | Frigidaire GLER642A Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
Have went through 2 dryers and its still tripping breaker. House is only two years old. Could it be the breaker anyway? I don't understand how it could still be the dryer. Both dryers had to have the new 4...
yes. The four prong cords have inherent problems with their electrical consumption. The same thing happened to my lawn mower with a four prong cord. Try reverting back to a 3 prong cord, then, if that doesn't work, you really might want to have an electrician look at the wiring. Some houses are cheaply made, and the wiring is usually the first sign. If you have a prefab home, this might just be the problem.
Hope this helps
Jul 11, 2009 | BaByliss Dryers
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
After conversion from 3 prong to 4 prong dryer wont work
YOUR FOUR WIRE CORD IS AS FOLLOWS RED,BLACK WHITE AND GREEN ON YOUR DRYER YOU HAVE FROM LEFT TO RIGHT 123 CONNECTIONS THE TWO OUTERMOST(1 AND 3) ARE HOT LEADS SO HOOK RED TO 1 AND BLACK TO 3 NOW HOOK WHITE TO 2 AND THE GREEN CAN BE ON THE TERMINAL COVER SCREW OR NOT AT ALL BUT BE SURE IT CANNOT COME INTO CONTACT WITH RED OR BLACK
Apr 27, 2009 | Estate TEDX640JQ Electric Dryer
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Bought used dryer. Plugs don't match. Can cord be switched?
Yes, these cords can easily be switched. When you remove the three prong cord from the terminal block in the rear of the unit, you will wire the four prong in the same way. Black and red go to the outside terminals, white to the middle terminal, and the green wire goes to the cabinet or ground screw on the outside (usually, there is a greenish looking bolt around the terminal block door area for this to go). The only difference in a 3 and 4 prong configuration is the extra ground (green) wire. Good luck and let me know if you need further information.
Feb 01, 2008 | Maytag Performa PAV3200
Dryer electric cord
The national electrical code requires the installation of a four wire system for ALL 240 volt equipment. He will be putting in a four wire dryer receptacle. The pigtail you'll need will be a standard four wire pigtail. The way it is connected is: the red and black go to the two outermost terminals, the white goes to the center terminal and the green goes to a good chassis ground point. If there is a jumper strap from the center terminal to the chassis ground point it must be removed.
Oct 01, 2007 | Dryers
Roper REX4634KQ Electric Dryer Logo
152 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
