Coleman deluxe blend air ll it starts up
Coleman deluxe blend air ll it starts up blowing cold air,then turns just to a little cool air, on the inside A coil starts freezing at the bottom of the A coil first,then starts freezing all the way to the top. The A coil is clean,the outside coil is clean. What next? Are there more filters to clean on this unit,is there any type of reset and is there a fuse that might have blown that I could replace?
  • 901 Answers
The blowing fan is not rotating at the rated speed. Check the fan capacitor and replace.
Check motor also if the capacitor is not at fault.
Posted on May 27, 2010
1995 wind star min van blowe cool in rear and hot air in front plenty freeon fues are good
I would check the blend door actuator. If the door is open all the way, one direction, the air blows over the heater core. All the way in the other direction, the air blows over the evaporator. Anywhere in between, a blend of hot and cold for temp control. That explanation is a little simplistic. the info is for ford windstar.
Jun 09, 2016 | Cars & Trucks
The heater kicks on but only blows cold air
Air Temperature Control Blend Door Failure No Heat or no AC (dependes on where door sticks)
In all modern cars there is a tiny DC electric motor driven gear drive that moves a plastic door that blends heated and cooled air from the AC and the heater core, this is called (interestedly enough) the air temperature control blend door actuator. The motor that moves this door fails because the door starts sticking from warping, most common complaint is no heat but it can be no AC as well. To replace these parts (blend door and blend door actuator) you must remove the entire dash from the car. Always have this problem confirmed by a dealer or qualified repair shop as it is a very expensive repair.
Other causes of no heat in the cabin are engine thermostats that are stuck open (engine runs cold) or air bubbles in the cooling system.
Jan 03, 2013 | Cars & Trucks
My coleman central electric furnace only blows cool air
The AC unit outdoors must be running and rejecting heat by its air flowing through it the 2 copper lines are the refrigerant lines, the fatter one should be "beer can cold" if not its low on refrigerant or not running.
Jan 01, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
No heat blows cold air
Oct 24, 2012 | 2004 Mitsubishi Lancer
No heat 06 sonata only blows cool air
it most definitely is your blend door. It's a bit of a hassle but in the end it doesn't cost anything but a sore back/neck and hands. Take your time. remove glove compartment, and you'll see the blend actuator. I unplugged mine as it was stuck in 'cold' mode. after re-plugging it worked again and has been fine since.
Oct 03, 2012 | 2006 Hyundai Sonata
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
No heat air is blowing cold
First you have to identify what causes the problem.
To do this you have to:
1) When engine is cold check the level of coolant. If it is low fill it up.
2) Start engine and check if engine reaches regular temperature. If your engine is not heated enough it means your thermostat does not work properly and should be replaced.
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is worm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
4) If pipe/pipes are hot/warm, turn off the fan, switch controller to the hot position, wait for 3-4 minutes and turn on the fan. Note if the cold air blows first or warm air blows first but it cools down in 5-10 seconds. If the air blows cold than it is most probably the problem with blend door or blend door actuator.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest to flush the heater core.
Oct 22, 2009 | 1998 Ford Taurus
MY 1998 FOR TARUS HEATER WILL NOT WORK.WAS DRIVING
It is most probably the problem with blend door or blend door actuator. But just in case I would suggest to follow the entire procedure:
3) If engine temperature is normal, then check the temperature of pipes that go to/from heater core. These pipes are located up the fire wall (easier access is from the passenger side). If pipe/pipes are cold (even engine is warm) it means you heater core is plugged and should be flushed. Keep in mind, flushing the whole cooling system is different from flushing heater core.
5) If air blows warm first and then cools down, then while running engine and remaining the transmission in PARKING position, press on the gas pedal until your engine reaches 3,000 RPM. Check if your heater blows warm/hot air. If it does, then your water pump does not work properly and should be replaced. If the air still cold, I would suggest flushing the heater core.
Oct 17, 2009 | 1998 Ford Taurus
Heater not working
Heating & Cooling Logo
155 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
