Question about Linksys Wireless-N WRT150N Router
My router will not let me connect to the internet
My linksys wrt150n router will not let me connect to the internet wired or wirelessly.
how can i fix this?
  • Jack Briner
    Jack Briner May 27, 2010
    Are you connecting to a cable modem or DSL?
  • raejonsky May 27, 2010
    i am connecting to a cable modem.
    when i plug my ethernet directly into the cable modem it works marvelously.
    when i go through the setup wizard to connect the router i get nothing.
    also, when i try to connect to the router with my ethernet it doesn't work either.
shoran
  • 54 Answers
SOURCE: cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Posted on Jan 15, 2009
  • 73 Answers
SOURCE: Linksys wrt160N router inconsistant internet connection
Check on your cables makes sure they are inserted properly and the cord should be free of kinks, scrapes or loose connections......Also check the back of your computer make sure your ethernet card (the one that has the green lights/LED's) is seated properly (not loose)....
Good Luck.....hope this helps...if not let us know....cheers
Posted on Apr 13, 2009
  • 9 Answers
SOURCE: Linksys Wireless-G not connecting to internet
Make sure you are plugging the SMC into the WAN port on the Linksys router and not the LAN ports.  Your internet connection (which is your SMC) should always plug into your WAN port on the Linksys.  Any computers that you may need to plug in, like Desktops that are "wired" and not "wireless", should plug into the LAN ports on the Linksys.  If you are not using the WAN port on the Linksys for your SMC modem, then that would explain why you cannot get to the internet on wireless or wired computers.
Here's why you are getting the "low connectivity" message:
Computers don't understand why the Internet is connecting or not connecting...so the "low connectivity" message you keep receiving has nothing to do with your wireless signal strength.   To a computer NIC, "low connectivity" means your network adapter could not find a DHCP server and receive a valid IP address.  When this happens, your network adapter assigns an IP address to your computer in the following range...169.254.0.0, and will display the "low connectivity" message until it is able to receive a valid private IP address from the DHCP server.  You can verify this by going to START | RUN and typing "cmd" (without the quotes), then hit ENTER.  A black box will pop up....then type "ipconfig" (without the quotes) and hit ENTER.  This will show you your IP address, subnet mask, and gateway address, and you can verify that your IP address is in the 169.254.0.0 range.  A valid private IP address is typically in the 192.168.0.0 range, but could also be in the 10.0.0.0 range, or the 172.16.31.0 range.    Also, make sure you have DHCP server enabled on the Linksys router for the LAN.  This will ensure your "wired" and "wireless" computers receive a valid IP address.
The WAN port on your Linksys router should be configured to "Obtain an IP address automatically using DHCP".
Cheers!
Posted on May 01, 2009
  • 55 Answers
SOURCE: Problem with VPNand Linksys router WRT150N
If that is the case you may forward ports on the router for VPN connection, try to open 47, 500 and 1723 all TCP and UDP protocol.
Here's what you need to do, check the IP address of the computer where you have the VPN software,
here's how:
click start> run> type cmd> hit okay
on the black screen put in ipconfig and check the IP address there,
> when you get the IP address then we can enable port forwarding on the router
> open IE on the working computer on the address bar, type 192.168.1.1
> nothing for username and password is admin in lower case
> then click on the applications and gaming tab on the router,
> and from there, example of how to field that in is like this,
> for aaplication name - VPN1
> for port it is 47 to 47
> for protocol it is BOTH
> for IP address ex. 192.168.1.XX - 192.168.1.100
> then check enable, do the same thing for the rest of the port.
> save the settings and try it again after.
> if it is still nothing, you may connect the computer that has the VPN connection directly to the modem and check if you will be able to connect via VPN
i'll wait for your response, thank you and have a nice day!
Posted on Jul 15, 2009
Macs R We
  • 481 Answers
SOURCE: wireless indicator light doesn't light up and
The "Wireless" light doesn't indicate that wireless is available, it indicates that wireless is being used.
You need to narrow down your problem statement by what symptoms you are seeing. Does your PC "see" the wireless router? Does the router accept your connection password?
Then follow the troubleshooting script in the user manual at
http://downloads.linksysbycisco.com/downloads/WRT150N_ug,0.pdf
Posted on Nov 25, 2009
My wireless connection is running super slow AND I cant access the router via 192.168.1.1
You can try to reset your router
Reset the Linksys WRT150N wireless home router if you are experiencing connection issues or have forgotten your customized router login information. Resetting the Linksys WRT150N will erase your Internet connection settings, wireless security preferences and all other personal settings from the router. This procedure will restore the WRT150N back to its factory state.
Instructions
1 Locate the "Reset" button on the back panel of the router. The button is situated to the right of the Ethernet ports and to the left of the power port.
2 Press and hold the "Reset" button.
3 Release the "Reset" button after approximately five seconds. The device resets
Tips & Warnings
Use the Linksys WRT150N setup CD-ROM to run the setup wizard and reconfigure the router after the reset.
Dec 29, 2011 | Linksys Wireless-N WRT150N Router
How to fix the router? it always says Router not found... I've been doing the steps again and again but it didn't work... I've already reset the router..still router not found... grrgrrrrr...my router is...
Are you trying to connect through wireless or using an Ethernet cable? If you've just pulled the modem out of the box, you shouldn't be able to connect and configure through wireless. You will have to connect up an Ethernet cable, go into a Internet browser, and type in the IP address of the router. From there, you can configure your router providing you have the login details of the router
Apr 15, 2010 | Linksys Wireless-N WRT150N Router
Slow internet for my hardwired computer
its because ur belkin routers MTU is not properly configured in the products ... u need to lower doen the MTu speed ..
Sep 25, 2009 | Computers & Internet
Cannot access internet through WRT150N router wirelessly OR wired
Same problem here, the motorolla surf board works way better. It also coult be your ISP.
Apr 02, 2008 | Linksys Wireless-N WRT150N Router
Cannot detect the router
What version of the router do you have 1,0 or 1,1? This is located on the bottom of your router. There is a firmware update for both models, I will provide link. Also how is your laptop connected wired or wireless? Let me know and I will try to help you troubleshoot your problem. We always can set up your router manually.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1169671597537&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=9753741396B13&displaypage=nodata&proxyid=1172713508141
Jan 10, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
59 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
